Hahn Header Install Problem *Pics*
Old Apr 13, 2008 | 12:19 AM
ColeJJones's Avatar
Bannned
i will tell you right now with about 100 plus others on this site that will agree to get a zzp combo
BlackSSNick's Avatar
I was thinking about sendin the hahn back and gettin the zzp tog header. I'll just have to buy a spacer for it so it fits, I think thats what I have to do with this hahn header as well, but the primairie holes are just too small.
Old Apr 13, 2008 | 12:25 AM
ColeJJones's Avatar
Bannned
you will be happy with the zzp shorty. all stainless design plus their name backs it up. it a sexy thing to look at. dont forget to get it coated
Old Apr 13, 2008 | 12:26 AM
stage2's Avatar
i wanna get a cat back and i was just looking at zzp 3'' they say it sounds as stock ....if so i will buty one asap
dont need ant cop attention lol
zzp makes good stuff
it's already coated isn;t it? the 200 dollar one
Old Apr 13, 2008 | 12:28 AM
ColeJJones's Avatar
Bannned
im pretty sure you have to opt for the 100dollar option on it...
yea, i talked to someone there about 2 months ago, and they told me if sounds just as quiet as stock. they tried a least a hundred different resonators and muffler combos to get it right. plus its a true 3" exhaust. pretty ******* cool to have a quiet 3". almost unheard of
Last edited by ColeJJones; Apr 13, 2008 at 12:28 AM. Reason: Automerged Doublepost
this one is already ceramic coated
http://www.zzperformance.com/cobalt_...=544&catid=155
Old Apr 13, 2008 | 12:32 AM
ColeJJones's Avatar
Bannned
here is the one you want if you want to go with a shorty
http://www.zzperformance.com/cobalt_...=543&catid=155
they are both great designs. go with the zzp if you have the money. either way you should have the same power coming out. not much difference except for the 4-2-1 on the zzp and the 4-1 design on the tog. i know the zzp is stainless and im not sure what the tog is made out of. at least you know that the zzp wont rust
Last edited by ColeJJones; Apr 13, 2008 at 12:32 AM. Reason: Automerged Doublepost
Old Apr 13, 2008 | 01:38 AM
IonNinja's Avatar
do NOT buy that TOG header
from the description, it looks like one of the bad headers that had a warped flange and some other issues...there was a big issue back in the day on RLF about them. probably why that is listed as a used part as well.
Old Apr 13, 2008 | 01:54 AM
turboeco's Avatar
I bought this header back when it was first released.
Sadly, I had the EXACT same problem.
I chose to go with a different header, instead of waiting for another.
Old Apr 13, 2008 | 02:00 AM
  #36
so i'm not alone. Did hahn give you your money back?
Old Apr 13, 2008 | 11:41 PM
  #37
*TRIX*'s Avatar
the header looks like its made wrong and almost as if the plate to bolt up to the motor was the opposite way cause if u were to flip the entire header over it looks as if it would fit
Old Apr 14, 2008 | 02:01 AM
  #38
2K5SS/SC?'s Avatar
I'm not a rocket scientist here, but if I had a fitment issue with someone's product I would call them directly and tell them my issues. Perhaps, Bill at Hahn would not only be able to correct the problem for future customers, but he may send you a new header with the issue fixed and help/reimburse you out somehow for your troubles. Bill stands behind his products and is very customer service oriented, so I'm sure he would be willing to go the extra mile.
As for other manufacturer's products to look at, I have the Custom Tubes Inc. 4-1 longtube header/downpipe. It works awesome and fits pretty good. You have the option of a 2.5" downpipe outlet or the full 3.0" outlet.
Old Apr 14, 2008 | 10:44 PM
  #39
Hahn is a great company, I am not saying they are not a great company. Bill is a great person to deal with as well. Don't hesitate to buy a Hahn exhaust system, but i'm definitely going to send the header back. They explained to me how to fix the problem, all you have to do is turn down the tubing for the water pipe and it will clear it. But knowing my luck i'll **** it up some how lol.
Old Apr 14, 2008 | 10:51 PM
  #40
Red2.4SS's Avatar
I havent been that impressed with customer service myself relating to another issue.
But yes you can rotate that coolant pipe out of the way!
Old Apr 14, 2008 | 10:55 PM
  #41
Rage915's Avatar
the header they sent me has smaller primaires then the stock header though. Why should I take the chance of them sending me something else when it will probably be the same size primaries as the one they sent me, and it doesn;t even have a 3" exit, it's only 2.5" that isn't a true 3" header.
there exhaust system is a stepped system headers are 2.5 dp is 2.75 and exhaust is 3.00. **** happens bro no need to bash, ive had issues with there down pipe and the sent me a new one, great customer service, imo
Old Apr 14, 2008 | 11:01 PM
  #42
Screamin!'s Avatar
i have the full hahn exhaust, and didnt have any problems with it at all....
Old Apr 14, 2008 | 11:03 PM
  #43
ColeJJones's Avatar
Bannned
has hahn responded to this thread yet??
Old Apr 14, 2008 | 11:14 PM
  #44
Hahn RaceCraft's Avatar
So I went to install the rest of my exhaust today, the Hahn cat-back is already installed. I took off the dp, and I took off the stock header (which is a pain in the ass). I go to put the hahn header on and it fits, but the bottom of the header rests on a part of the transmission. The transmission piece goes across to the other side of the tranny. When I tighten the header down, the pressure from the header pushing down on that bar causes the transmission to leak on the right side where that bar goes across. So I take the header off and I compare the openings with the stock header, the stock header has bigger openings. I'm either thinking this is very poor design, or hahn sent me the wrong header? I need some answers.
Size Comparison (look at the holes on the new header (left) compared to stock (right)
The openings in our header flange are designed to fit the port in the head, whereas the stock manifold's openings do not. An examination of the head's port openings will illustrate this.
The weekend rather got in the way of us supporting this customer...on Sunday night, my staff made me aware of his email to our Sales Department describing his findings, and I set the wheels in motion to lend a hand this Monday morning. I was not aware that this thread had been posted until I came across it rather by accident while here posting about other things.
We've been in touch with the customer regarding the correct procedure to compensate for the variations in the coolant pipe on the LSJ engines. As someone noted in an earlier post, it's an easy fix. We'll be amending instructions for this product in the future with this information so as to prevent further satisfaction problems, especially on weekend installations! We've sold dozens of these headers, and only seen this occasionally in the past, and our existing Tech Support system was able to address it well when it did come up.
For those who are wondering just what's up...there are variations in the production of the coolant pipe on the LSJ. Our header is TIG-welded on a fixture that has positive stops to locate the tubes effectively in the region of the coolant pipe, but the coolant pipes themselves vary somewhat...apparently, as the stock cast manifold is considerably further away from the coolant pipe than our tubular header, it's not an issue GM was concerned with, and GM could thus make the pipes to a very wide shape tolerance. The fix is easy...we just rotate the pipe slightly on its O-rings to a location that clears the header.
Our apologies for any consternation this all caused to BlackSSNick. We live and learn, and his experience will enable us to improve our product's documentation for future purchasers. It's not often that we have to make instruction revisions this far into a product's life cycle, but we do what we have to, when we have to!
Old Apr 14, 2008 | 11:24 PM
  #45
Brandon97Z's Avatar
Thats what i was about to say.
Old Apr 14, 2008 | 11:32 PM
  #46
ColeJJones's Avatar
Bannned
yea me too....
Old Apr 14, 2008 | 11:50 PM
  #47
Originally Posted by SlowBalt_06
i guess they were more worried bout making a gt35r cobalt than getting there header right
Oh now that's just wrong! The turbosystem fans need love too...I'm sure they would prefer all I did was make turbosystems for them and stay away from header production altogether!
Old Apr 15, 2008 | 10:30 PM
  #48
bill your a good man!
Old Apr 29, 2008 | 04:20 AM
  #49
eckow8's Avatar
So to all you guys running the hahn full exhaust (headers, dp, 3in exhaust) how do you like, how does it sound, fit and finish (other than this minor problem that was resolved)?
Old Apr 29, 2008 | 08:34 AM
  #50
RedEcotecSS's Avatar
ZZP ftw!
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
