Hahn Racecraft LSJ GT35R Turbo Project PICS RELEASED!
Old 12-23-2007, 08:27 PM
  #151
Hahn RaceCraft's Avatar
Originally Posted by Rodimus_Prime
That piece alone makes this kit worth getting but again
prices?
turbo options?
I have to emphasize that it's impossible to quote accurate turbosystem pricing until the systems are completely developed and the resultant bill of materials can be costed out. Bear with me, lol...it's much better to be accurate!
The turbo options have been outlined here...Super 20G and GT35R.
Originally Posted by 06blackg85ss
that **** is purty.
How much you think that manifold is gonna run minus the injector provisions
Why thank you! That I can price, for we've got that costed out...approx. $750. Not inexpensive, mind you, but a lot of handiwork and expensive machining goes into one, and the price is comparable to what you'll see out there for similar applications such as Evo, Eclipse, Honda, the like.
Originally Posted by spaz
What controls the extra injectors.
They are controlled by an electronic module that is easily programmable via two-axis maps of boost and RPM. The module has its own MAP sensor for up to 30 PSI of boost. Very straightforward to tune, easy to understand software.
Last edited by Hahn RaceCraft; 12-23-2007 at 08:28 PM. Reason: Automerged Doublepost
Old 12-23-2007, 09:09 PM
  #152
jgarciarivera's Avatar
Hey Hahn
I got a return-style fuel system. I think I would not need the port fueler. Can I buy just the turbo, piping for intercooler and intercooler only?
  #153
06black's Avatar
Bill what are the lengths and ID's of thouse runners?
the port centers are the same as past eco's correct?
Old 12-23-2007, 10:02 PM
  #154
Originally Posted by jgarciarivera
Hey Hahn
You sure can. We will offer the complete turbosystem less fuel mods in a 'Tuner' version. Add your own fuel system mods and tune away!
Old 12-23-2007, 10:04 PM
  #155
Moderator Alumni
zinner's Avatar
I am excited, can't wait to see what you guys have for me.
  #156
Bill what are the lengths and ID's of those runners?
The lengths are approximately 6". The ID's are harder to define, as they are oval shaped. Suffice to say, it's identical to the cylinder head's port entry.
Yes, the port centers are the same as past Ecotecs.
Old 12-23-2007, 10:09 PM
  #157
Dayta's Avatar
OMG
when is it my turn? haha
deff cant wait to see some vids and the numbers that thing is gonna pull out
Old 12-23-2007, 10:36 PM
  #158
06black's Avatar
excellent.
thank you sir.
awesome piece!
when will they be available for purchase??
also, does the intake mani allow for porting the TB space for my lager ls4 unit?
Old 12-23-2007, 10:38 PM
  #159
spaz's Avatar
lets start a list for the group buy.
1)spaz
Old 12-24-2007, 01:42 AM
  #160
Asphalt Assault's Avatar
you would seriously would be signing up to buy already without a price? without knowing what it can do for sure? without seeing the powerband?
LOL
Old 12-24-2007, 07:31 AM
  #161
Sw4y1313's Avatar
Hey Bill, got a question for ya. How much would the port fueler system be without the tuning for it? Just the manifold w/ injector ports and the fuel rail. I am planning on doing a similar setup(secondary injectors) but with the procharger. What size injectors are you using there? If there what im looking, what would be the price with injectors? Would you rather me shoot you a pm? Im trying to weight out all my options here, Thanks bill!
Old 12-24-2007, 08:19 AM
  #162
06blackg85ss's Avatar
no need to explain pricing to me, I know how expensive things can be on cars. That's a pretty reasonable price IMO for that intake. Let me know when it's gonna be available cause I would like to scoop one up very shortly
Old 12-24-2007, 08:31 AM
  #163
spike's Avatar
that is very cheap...................i thought it would be mroe like $1200................this part may have 2 make its way onto my car very soon..............
Old 12-24-2007, 10:53 AM
  #164
spaz's Avatar
LOL
Yup,Cause I'm crazy like that.
Old 12-24-2007, 03:49 PM
  #165
MVP
MVP's Avatar
AHHHHHHHHH HAAAAAAAAAA!!!!!!!!!!!!!!!!!
thank you sir, you just proved a point to myself.
yea, i know it sounds crazy.....when i was graphing out car i came up with either a T3 flange with a .63AR or the next step up T4 with a .58
and the 10CM hotside on your 20g also sides well with my past research.
I know Bryan you've mentioned those numbers to me before.
Old 12-24-2007, 03:53 PM
  #166
rguti153's Avatar
PRETTY
Old 12-24-2007, 04:08 PM
  #167
handyjoe's Avatar
Bill,
What size injectors will the PortFueler be running?
Old 12-24-2007, 05:16 PM
  #168
MVP
MVP's Avatar
Originally Posted by handyjoe
Bill,
42s I bet.
Old 12-24-2007, 05:23 PM
  #169
articzap's Avatar
^What are you smoking? A 35r has got to be well over 60 lb/hr. Most likely 72 lb/hr injectors.
Old 12-24-2007, 05:26 PM
  #170
SSdan's Avatar
Originally Posted by MVP
42s I bet.
Um...42's IN SYNC with the regular injectors...
Old 12-24-2007, 05:27 PM
  #171
MVP
MVP's Avatar
Not if your using a return style fuel system. and if im not mistaking they're using 8 injectors so no need for 60s or 100s BTW a GT35 with a returnless style system like the SS S/C has is going to require more like 100 LB/HR/,000 CC injectors so i must ask you the same question What it it that you are smoking. not exactly a noob man. look at my sig and unlike most people I do alot of my own work.
Old 12-24-2007, 05:28 PM
  #172
you speak the truth man
Old 12-24-2007, 05:40 PM
  #173
articzap's Avatar
Didn't notice the two injectors per cylinder. 72 lb/hr on a return single injector setup for a 35r would be around the right size.
Old 12-24-2007, 06:05 PM
  #174
06noscobaltss's Avatar
I am running a set of 60# on the stock rail and the portfueler will have a set of 48# injectors.
Old 12-24-2007, 07:11 PM
  #175
Moderator Alumni
zinner's Avatar
Did you upgrade the fuel system in anyway? Pump/filter/lines wise?
Quick Reply: Hahn Racecraft LSJ GT35R Turbo Project PICS RELEASED!
