HAHN -vs- JPB Header
Old Jun 3, 2009 | 12:53 PM
  #51
1badBlueberrySC's Avatar
Eat it Cockboy
Old Jun 3, 2009 | 12:55 PM
  #52
Cefaln452's Avatar
did it seem to help?^^^^
Old Jun 3, 2009 | 12:57 PM
  #53
ShortStack's Avatar
Originally Posted by Cefaln452
well i can get it FOR FREE so why not stainless... plus it holds heat better the ceramic coated alsooo
I can assure you the statement of stainless holding heat better than A CERAMIC COATING is false.
  #54
Yep... but all this car needs is QUICKER turbo spool!
hence the ::facepalms::
Last edited by 1badBlueberrySC; Jun 3, 2009 at 12:57 PM. Reason: Automerged Doublepost
Old Jun 3, 2009 | 12:58 PM
  #55
ShortStack's Avatar
<--- 20psi at 4k... Think im too rich down low though.
Indeed sir.
Old Jun 3, 2009 | 12:59 PM
  #56
****... I spike to 25 by 3500 holds 22psi for the duration dropping to about 20 at 7000
Old Jun 3, 2009 | 01:08 PM
  #57
Cefaln452's Avatar
i assure it does not.... research it... its plain chemistry and physics
Old Jun 3, 2009 | 01:27 PM
  #58
ShortStack's Avatar
Okay. so what happeneds when you put rubber over a hot pipe? It insulates it. You dont feel the heat on the rubber. Same concept. The metal without any insulator is going to expunge its heat. With the ceramic coating, it insulates it...
THATS plain physics.
Go tell nasa that they are wrong in using a ceramic type plating to make sure their shuttle doesnt just disintegrate during re-entry and everybody doesnt melt on the inside.. they should be using stainless steel instead.
Old Jun 3, 2009 | 01:30 PM
  #59
Cefaln452's Avatar
stainless has a different composite... hence why it is more expensive... and when using 304 medical grade... it has an element added which is far superior that a ceramic coating...
theres stainless and theres medical grade... depending on the application and the needs they are altered... hence why they make a cobalt, the a g5 then a redline... different applications
Old Jun 3, 2009 | 01:32 PM
  #60
ShortStack's Avatar
Stainless is better with heat than Mild. But they do ceramic coating for a reason. hence why NASA uses it for the space shuttle.
Old Jun 3, 2009 | 01:57 PM
  #61
HunterKiller89's Avatar
u sir = wrong. ALL steels, including T304, conduct heat ridiculously well. This means heat will be able to dissipate to the outside, leaving the exhaust stream. Ceramic coating does NOT conduct heat very well, so it insulates the T304.
go retake chemistry
Old Jun 3, 2009 | 01:59 PM
  #62
ShortStack's Avatar
Yea.. seriously...
Old Jun 3, 2009 | 06:16 PM
  #63
Cefaln452's Avatar
how bout you do some research and come back once you figure your **** out... Good bye...
how bout both of you call CIA and ask them... they'll teach you
Old Jun 3, 2009 | 06:27 PM
  #64
all you have to do is post the reasoning behind your "physics" that makes your sentence true...
however, i already posted the chemistry behind why what shortstack and I are saying, and you would have to prove that false (which you cant do because it is fact) before you could say you are correct and we are the ones who are misinformed.
so, either prove us wrong, or admit defeat by pulling the typical "you guys are stupid, you're wrong, but im not gonna explain why" that 12 year olds love so much
kthnxbai
Old Jun 3, 2009 | 06:39 PM
  #65
damien's Avatar
Ceramic coating kicks ass. It's durable and holds the heat in.
Old Aug 5, 2009 | 10:47 PM
  #66
tambrico's Avatar
Sorry for the bumpage...but what do you mean by "medical grade"? Surgical instruments like scalpels typically use 440C steel, not T304.
Old Aug 6, 2009 | 12:03 AM
  #67
he didnt know what he was talking about. T304 is used in the food insudtry, and possibly for hospital appliances
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
z28addiction
Sep 28, 2015 12:03 AM
Sep 27, 2015 08:53 PM
