Harrop: Fuel Problems!
Old Jun 10, 2010 | 10:12 AM
thebucky84's Avatar
Well i had just installed my Harrop s/c a day ago and loaded the tune (given to me from ottp based on the set up i purchased). I couldnt get the converter off on my own so i didnt get my test pipe in. I then unplugged the 2nd o2 sensor, checked off and set them to 3 on the dtc list. I plugged my wideband in there.... well at idle it runs pig rich, like 10 afr, but if you wait a few secondsit starts lean out. I took it for a real short ride and every time i stop it will go pig rich and idle will bounce and eventually settle. Also when im at cruising speed and i let up on the throttle a little it will go to 10afr, but as i accelerate it will lean back out to 14.7 afr.. can anyone shine some light on me?
side note: ottp sent me the tune expecting the converter to be out
Old Jun 10, 2010 | 10:39 AM
Omega_5's Avatar
For starters... you can't use your wideband in the 2nd O2 bung if you still have the catalytic in place.
Second... what injectors are you running?
Old Jun 10, 2010 | 10:40 AM
thebucky84's Avatar
yeah, thats what i figured. I have 80# injectors
Old Jun 10, 2010 | 10:45 AM
Omega_5's Avatar
If the tune doesn't already have it done; zero out the Short Pulse Limit, and re-tune your idle.
Old Jun 10, 2010 | 10:51 AM
thebucky84's Avatar
yeah the short pulse is at 4.000 msec right now, what will that do for me? and im assuming thats with the 2nd o2 sensor back in the car?
Old Jun 10, 2010 | 11:11 AM
Omega_5's Avatar
The catalyst and 2nd O2 have nothing to do with the issue, besides the fact that your aren't getting an accurate AFR reading.
It's the fact that the injectors are so big, that they are injecting more fuel than the car can handle at idle. By zeroing out that value and re-tuning the idle, you are effectively shortening the injection pulse, and injecting less fuel at idle or low load.
Old Jun 10, 2010 | 11:26 AM
thebucky84's Avatar
ok, well not to sound like a sorry noob but what tables do i need to edit for idle?
Old Jun 10, 2010 | 11:44 AM
Omega_5's Avatar
I take it you aren't familiar with HPT, huh?
Well, maybe call either Sean or Josh at OTTP, and get them to help you out with that... cause you pretty much need to learn how HPT operates, and how to either tune via trims or AFR before you can dial in the idle fuel.
Old Jun 10, 2010 | 12:50 PM
thebucky84's Avatar
well im familiar with hpt, just trying to get use to and figure out what tables to make changes to for certain applications. I've tuned with my buddy using hpt before, but he is in japan now. I catch on pretty quick, just need a little guidance
Old Jun 10, 2010 | 01:10 PM
Omega_5's Avatar
Well, head over to the HPT forums... read the FAQ section, read the manual, and read the 'how to tune' thread over on RLF.
If you still have questions, just post up on HPT and we can get you rolling.
Most of us tuners don't post much over here with respect to HPT, simply due to the fact that too many people want to get spoon fed information, or just start asking for canned tunes. So, that's why I've directed you to the other forum (HPT).
Old Jun 10, 2010 | 01:53 PM
thebucky84's Avatar
i hear ya, im actually on the hptuners site, i was just seeing what people had to say on here. but thanks a lot man!
turbochargedss2012
Sep 20, 2023 12:17 PM
no_ss
Oct 18, 2015 11:58 PM
DocSvensk
Sep 27, 2015 02:24 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
