Harrop is on, issues
Old May 4, 2008 | 01:44 AM
Rodimus_Prime's Avatar
Cool Harrop is on, issues
First off let me say that holy crap this thing had to be shoehorned in there. The bottom two bolts were virtually impossible to get on. Looks great though , im using the 3.5 inch pulley, sorry for no pics, I got done when it was dark, maybe tommorow.
Ok main issue is IAT, its 53 degrees out and IAT2 constantly stays at 105, this seems quite a bit high, odd thing is when I give it maybe half throttle the temp decreases at least by 25 degrees, full throttle it doesnt go above 105 at all, even after punching 7k a few times. I am using the stock bypass valve.
Overall you cant hear it at all, I kinda miss the whine, but cool noises arent everything
Old May 4, 2008 | 08:17 AM
WickedSS2005's Avatar
You have a PM. Did you check all the connections when you reinstalled all the sensors? Check your fuses to see if any are loose. I had a car I was tuning the other day throw codes out the ass after flashing. Couldn't figure it out for the life of me. Some of the ECM fuses were loose
Old May 4, 2008 | 09:55 AM
I only had to unplug one sensor, so thats in there ok, I didnt change any fuses , i have no codes
Old May 4, 2008 | 09:57 AM
lsjwannabe's Avatar
if you ground down the bolts it would work easier becuase of the clearence issue, harrop to care of that for the production models though
Old May 4, 2008 | 11:16 AM
getting to the lower bolts was the problem theres not much room between the bottom of the charger and the two lower screws, my arms look like I was fighting with Wolverine
Old May 4, 2008 | 11:21 AM
Sunburst_SS's Avatar
yea, the bolts were a pain to get it......I put them in before I put the blower in the car...then used an allen wrench I modified to tighten them down.
Old May 4, 2008 | 11:30 AM
yea i had to do them with my fingertips till they were in enough for me to get the allen wrench in
Old May 4, 2008 | 11:34 AM
Raven SS's Avatar
glad to see another one up and running..mines going to be done saturday...
Old May 4, 2008 | 11:36 AM
2K5SS/SC?'s Avatar
Don't feel bad, I had to do the same thing with the twinscrew. It's the blower width that does it! This is a good thing though!
Old May 4, 2008 | 08:44 PM
Old May 4, 2008 | 09:15 PM
congrats man!! You'll be enjoying it in no time
Old May 4, 2008 | 10:47 PM
I'd be happy if my IAT2s werent messed up
Old May 5, 2008 | 11:50 AM
Any luck with that after we talked?
Old May 5, 2008 | 12:40 PM
nope , and P0171 popped up today
Old May 5, 2008 | 12:45 PM
huh, lean condition eh? Have you tuned it yet??? Inspect and make sure you have no open lines and everything is secure
BriantheLion26's Avatar
Looks good on there.
My arms are a bit cut up as well... Least it was for a good cause.
Old May 5, 2008 | 12:46 PM
06blackg85ss's Avatar
well when it's sitting at idle of course your IAT2's will be high, no air moving. If it's dropping while your driving or under boost, that's normal
Old May 5, 2008 | 01:21 PM
even crusing in 60 degree ambiant its well over a hundred on IAT2 unless i give it gas
its going into the body shop on wed to get rid of the ricer wing, i dont know if ill have time tommorow to get the wideband on or not
Old May 5, 2008 | 01:29 PM
Area47's Avatar
Rent me! per hour
check for air in the aftercooler system.
check to see if the pump is working.
bugs add horsepower
Old May 5, 2008 | 01:45 PM
I have option B there is no air, and the pump is working ive jumpered it
Old May 5, 2008 | 11:02 PM
GREAT JUST ******* GREAT
i broke the map sensor under the ******* blower , which doesnt fit for ****
anyone got a part number for the IAT2 map sensor , anyone want a harrop blower?
This is bullshit
Old May 5, 2008 | 11:04 PM
INFE's Avatar
I do but im broke lol
Raven SS's Avatar
thats what happens when u have a test pilot position bro..dont give u..u can do it
ralliartist's Avatar
This is bullshit
go turbo. (hides from everyone)
Old May 5, 2008 | 11:05 PM
eastcoastz's Avatar
I need that part number also anyone?
