Harrop is on, issues
Old May 5, 2008 | 11:05 PM
Sunburst_SS's Avatar
Originally Posted by Rodimus_Prime
GREAT JUST ******* GREAT
i broke the map sensor under the ******* blower , which doesnt fit for ****
anyone got a part number for the IAT2 map sensor , anyone want a harrop blower?
This is bullshit
How did you break the MAP sensor??? If you grind down the mounting tab and clock it to the side it will fit....
Old May 5, 2008 | 11:09 PM
black06ss's Avatar
sucks. my starting bid is 40 ducketts yo. but seriously good luck with it.
Old May 5, 2008 | 11:11 PM
Rodimus_Prime's Avatar
YOU CANT SCREW IT TO ANYTHING WHEN ITS TURNED TO THE SIDE
I just need a damn part number so I can get rid of this piece of **** and put the old M62 back on
Old May 5, 2008 | 11:17 PM
ralliartist's Avatar
wow. seriously dude, go turbo.
Old May 5, 2008 | 11:19 PM
someone just please find me a part number for the map sensor on the intake manifold
Old May 5, 2008 | 11:26 PM
I'm searching, but no luck.
Old May 5, 2008 | 11:30 PM
2K5SS/SC?'s Avatar
Go to the dealership and get the part number or call CED. Then, check out the TVS threads on here for how to properly mount it the MAP sensor.
BriantheLion26's Avatar
http://www.gmpartcatalog.com/partloc...&siteid=214551
No part number though
OK that didn't work. Just search for map sensor.
Old May 5, 2008 | 11:31 PM
ItalianJoe1's Avatar
I'll trade you mine for the Harrop...
Old May 5, 2008 | 11:36 PM
eastcoastz's Avatar
Yea, but it could be either the Iat sensor or the map sensor.
Old May 5, 2008 | 11:38 PM
  #36
If you can't get it, I could call my parts guy first thing tomorrow morning.
Old May 6, 2008 | 12:11 AM
  #37
i work 830-1230pm then ill go straight to the dealer
Old May 6, 2008 | 12:14 AM
  #38
eastcoastz's Avatar
I could only find the Bosch PN 0 261 230 042.
Old May 6, 2008 | 01:02 AM
  #39
I believe my parts guy gets there at 7:30 or 7am, not sure which. Could call him first.
Old May 6, 2008 | 06:50 PM
  #40
Well heres the update on where things stand
Drove the car to work this morn with little issue, went to the dealer, part does not come in till thurs because of course they didnt have it in stock and the part has to come from Lansing, MI
Then I went on home and pulled out the broken piece that was in the intake manifold of what was left of the map sensor then I got the bright idea to pop it back in just so i wouldnt have a hole in the intake manifold, well i pushed it into the intake manifold and so i had to yank off the harrop, the alternator, the intake manifold, jiggled it in the air till it came out, thank goodness it wasnt in the motor.
Just kinda slapped the intake mani back on as I cant really do anything till the sensor comes in, I also got 60lb injectors on 2 day shipping I just put in for, I changed the pulley from the 90mm to the 85 as that should be much easier to get the belt back onto and since im running 60s shouldnt be much of an issue there.
the new map sensor im going to wrap the outside in heat shield in hopes that it wont continue to produce false IAT2 temps this way. Im also getting a turbo/supercharger bypass valve code P2261? Anyone know what thats about?
Old May 6, 2008 | 07:16 PM
  #41
Might have left a line off the valve or solenoid that controls it.
Old May 6, 2008 | 07:21 PM
  #42
no everything is hooked up
Old May 6, 2008 | 07:31 PM
  #43
Solenoid is plugged in all the way as well, right? The little electrical box on the side of the engine.
Old May 6, 2008 | 08:19 PM
  #44
yea didnt even touch that
Old May 6, 2008 | 08:27 PM
  #45
Mnatvyc1223's Avatar
you should sell ur harrop to me...
Old May 6, 2008 | 08:37 PM
  #46
Pully Police's Avatar
You have 5...again...5 days to get fully tuned and provide dyno numbers.
Old May 6, 2008 | 08:40 PM
  #47
my_bd's Avatar
I documented the installation of my prototype HTV1320LSJ.
If you think it would help at all, you can PM me your email address and I'll send you a copy of my document, maybe it will help you double-check your connections etc.
Old May 6, 2008 | 08:46 PM
  #48
haha it might be tuned in 5 days but dynos arent happening
Old May 6, 2008 | 08:54 PM
  #49
eastcoastz's Avatar
Bro what is the part number of that sensor?
Old May 6, 2008 | 09:09 PM
  #50
no idea i just ordered it from the dealer but ill be happy to post up the part number when i get it on thurs or friday
