Has anyone run a Cobalt Addiction stage 3 ?
Old Jun 6, 2007 | 12:42 PM
qchadf's Avatar
Has anyone run a Cobalt Addiction stage 3 seems to be almost the same setup that I have.
I wanted to know if any one had a dyno sheet or AF read out for me to compare to.
Every is saying my setup is bad I want to compare.
2007 CObalt ss SC
ME
MAFT Version 6.22
2.6 ZZP Interchangeable Pulley system
3 step colder ngk IRIDIUM spark plugs
42# Lucas Injectors
Injector Wiring Harness
18.4 psi boost 6.4k RPMs
Devils own Meth/Water Injection M3 Nozzle
50 over stock. 255 HP 260 TQ
Cobalt addictions
Stage #3 : 2.7 ZZP Interchangeable Pulley system
1 step colder ngk IRIDIUM spark plugs
GM shortened belt , 42# Lucas Injectors
Injector Wiring Harness, Stage #3 Retune
... Est. 65 Hp over stock - 18 psi boost 7k RPMs
HP 270
Old Jun 6, 2007 | 12:45 PM
06blackg85ss's Avatar
well your setup is a recipe for disaster 42's with a 2.6 = blown motor
I was the c/a stage kit test car... feel free to pm any questions
stage 3 comes with 60's he just never changed the website
Last edited by 06blackg85ss; Jun 6, 2007 at 12:45 PM. Reason: Automerged Doublepost
Old Jun 6, 2007 | 01:17 PM
Acidangel_5.0's Avatar
2007 CObalt ss SC
ME
MAFT Version 6.22
42# Lucas Injectors
Cobalt addictions
HP 270
Pop goes the ectotec!
Old Jun 6, 2007 | 01:20 PM
poppagun's Avatar
Boom
Old Jun 6, 2007 | 03:11 PM
tum_tum's Avatar
Wow..i'm Worried Bout My 2.85 With The #42...wow Thats Why I Dont Go Woot Very Often
Old Jun 6, 2007 | 03:37 PM
SlayeR36987's Avatar
Well once u have the 60lbers how low would you go on the pulley size. I dont think 2.5 would b to good since it way to small and the stock M62 cant handle that much.
Old Jun 7, 2007 | 07:22 AM
well with the new blower setup going in (ceramic bearings and a few other tricks) I'm going to try and run a 2.35 pulley and see what happens. The car has held together so far with almost 20000 miles on a 2.55 pulley and 60s
Old Aug 31, 2007 | 01:54 PM
qchadf's Avatar
Update
Update I am running with 50lb Injecters on the MAFT and the 2.6 Pulley seems ok
CAr run great and I only use the meth at the track and only above 16 lbs of boost.
Old Aug 31, 2007 | 01:57 PM
BlueSS-supercharged's Avatar
you like the way it runs? any major problems? what have you beat with it so far? sucks having a slow car
Old Aug 31, 2007 | 05:39 PM
Shortbus's Avatar
I really think there needs to be a sticky on all the different stage kits, and what pulleys to run with what injectors.
Old Aug 31, 2007 | 09:15 PM
rallycobalt06's Avatar
that is the truth!!!
Old Aug 31, 2007 | 10:22 PM
qchadf's Avatar
Yea
My car runs and sounds like a cobra bad ass but the track proformance sucks right know becuase I have stock tires on 18inch and i wheel hop like basketballs.
Best I can run is 14.1 at 104
I am going to do a new right up you guys should like I will post it soon.
hawkssoccer11
Sep 30, 2015 12:14 PM
Sean Cummings
Sep 11, 2015 09:35 PM
Bluelightning
Sep 8, 2015 05:18 PM
CobaltSS 16
Sep 6, 2015 02:04 PM
NoBalt123
Sep 4, 2015 07:10 AM
