Having some problems...
Old May 7, 2009 | 01:32 PM
harryresh's Avatar
Just got my OTTP stg. 1 installed and im throwing a code for "random misfires". Im thinking i should just get it tuned at a local shop...any thoughts?
Old May 7, 2009 | 01:33 PM
D4u2s0t's Avatar
did you contact the guys at 0ttp? sounds like it would be a reasonable first step
Old May 7, 2009 | 01:42 PM
OntarioKev's Avatar
Did you install new spark plugs? What were they gapped at?
Kevin
Old May 7, 2009 | 08:11 PM
harryresh's Avatar
i set the plugs that came with the kit somewhere between .035 and .040
Old May 7, 2009 | 08:51 PM
D4u2s0t's Avatar
did you use a tool? becasuse somewhere between .035 and .40 is a decent difference.
Old May 8, 2009 | 11:31 AM
harryresh's Avatar
used a tool. it doesnt even idle smoothly so it cant be spark blow out...i will set it to .035 though
Old May 9, 2009 | 12:41 PM
harryresh's Avatar
just out of curiousity does anybody know anybody that can tune my car in PA? im located about 45 min SE of Harrisburg...
Old May 9, 2009 | 12:47 PM
Zach06CobaltSC's Avatar
ottp does great work with tuning, I would be surprised if it was a tune issue. I would contact ottp and give them your exact mod list and see if there could be a mix up of some sorts. Ottp is a great company with great people and I am sure they will get this issue resolved.
However if they don't I recommend that you purchase hptuners yourself and learn how to tune.
Old May 9, 2009 | 12:54 PM
harryresh's Avatar
thats fine but i was just wondering. hence the "out of curiousity"
Old May 9, 2009 | 01:05 PM
rico's Avatar
is it the p0300? code.
Old May 9, 2009 | 01:29 PM
wtpcobaltss's Avatar
my plugs are gapped at .045 works amazing for me... did u install everything ur self??? is it the right pcm? i sent them my pcm and got back a malibu pcm and mine did that but they fixed it immediatly.
Old May 9, 2009 | 05:59 PM
harryresh's Avatar
how could you tell it was for a malibu? was the pcm different physically?
Old May 9, 2009 | 08:37 PM
Dainslaif's Avatar
Yep, that's random misfires. It's pretty common with the OTTP kit.
Old May 9, 2009 | 09:52 PM
mattcossel29's Avatar
x2 mine still does it.. try to run the best gas you can. That helped solve my problems. I run ethanol enriched 93 octane from walmart
Old May 10, 2009 | 01:09 PM
rico's Avatar
yep that code is pretty typical i got it a few times. havent gotten it on again ever since i cleaned my tb. and took out all spark plugs and putted them back on again.
low_k3y
Jun 13, 2015 01:37 PM
riceburner
Aug 5, 2013 09:55 PM
xxBeaudsxx
Oct 14, 2012 12:03 PM
USMCFieldMP
May 6, 2011 05:30 PM
