HE pumping???
Old Aug 17, 2006 | 04:58 PM
joeworkstoohard's Avatar
HE pumping???
Okay, here's the plan. I am trying to find all of the goodies needed to install the M62 onto an LE5. So far, the install looks like it would be pretty straightforward (if a bit expensive). The question i have is, what pumps the coolant for the HE? is it a seperate pump, or does the blower pump it's own?
Old Aug 17, 2006 | 08:19 PM
automobiliben's Avatar
The HE and blower are two separate entities, the pump for the HE is attached to the block. I am not sure if it is gear driven or electric though.
Old Aug 17, 2006 | 10:06 PM
Doc's Avatar
Doc
electric pump, not exactly what drives it or if it is always on.
Old Aug 17, 2006 | 10:09 PM
just bolts on to the engine? well, if it's electric, should be easy enough to fab up/ attach.
Old Aug 17, 2006 | 10:34 PM
Doc's Avatar
Doc
It has a plug on the passenger side with a few wires.
I'll snap some pics tomorrow and post them up.
Also, take a look here
http://manual.lsjowners.com/engine/superc_2.htm
Old Aug 17, 2006 | 10:58 PM
zinner's Avatar
Moderator Alumni
Yep it's an independent electric pump that pumps the coolant through the circuit.
The supercharger is 100% self contained, no coolant, oil lines.
Sounds like a fun project, I believe the intake manifold/ic is like 350 bux dealer cost.
I would look into turbo kits, they are already developed.
Old Aug 17, 2006 | 11:04 PM
i have this thing about using as many GM parts as i can... it's nice to, in ten years, be able to walk into a chevy dealer and be like "one of these" my good man.
DarrenGC
Dec 24, 2021 01:55 PM
anotherslowlnf
Sep 29, 2015 03:52 PM
Adiaz1ss
Sep 26, 2015 11:51 PM
roth
Sep 26, 2015 12:16 PM
