Head Porting Tips???
Old Feb 20, 2010 | 10:01 PM
YzRider452's Avatar
Gonna be porting a couple heads soon, ive had some practice, i was just hoping someone on here could give me a couple tips for cobalt heads. Anybody have any good advice?
Come on? Nobody has any tips?
Last edited by YzRider452; Feb 20, 2010 at 10:01 PM. Reason: Automerged Doublepost
Old Feb 20, 2010 | 10:08 PM
elite_Cyborg's Avatar
most of the gains are picked up in the bowl behind the valve.
Old Feb 21, 2010 | 01:45 PM
Frew's Avatar
porting it not to be left to someone who "has had some practice"
Old Feb 21, 2010 | 02:02 PM
gotta learn somehow
Old Feb 21, 2010 | 03:01 PM
YzRider452's Avatar
Ive had experience porting heads, just not an ecotec head.
Old Feb 21, 2010 | 03:48 PM
cakeeater's Avatar
Do you have access to a flow bench?
Old Feb 21, 2010 | 04:10 PM
YzRider452's Avatar
Theres a place around here thats letting me use theirs.
Old Feb 21, 2010 | 04:16 PM
cakeeater's Avatar
Then my tip is take your time and don't push it. I can't tell you how many times I've seen people shoot for a certain number and end up going up, up, up, down.
Old Feb 21, 2010 | 04:30 PM
nicksredline's Avatar
when u go down is there any way to correct it? if i am buying a head thats ported but does not have a flow chart is there a chance i could be buying a head that will loose me power?
Old Feb 21, 2010 | 04:36 PM
cakeeater's Avatar
Yes, it's very possible. Was the head ported by an independent or a shop? Porting isn't just about making holes bigger. You need to increase flow characteristics and there are PLENTY of people out there that have no idea what they are doing and end up ruining the head.
Old Feb 21, 2010 | 04:38 PM
YzRider452's Avatar
You can seriously **** a port job up from takin too much out. All the porting ive done has just been smoothing and gasket matching. I wanted to take that a tiny step farther.
Old Feb 21, 2010 | 04:41 PM
cakeeater's Avatar
Just be careful. Do you plan on doing a valve job also?
Old Feb 21, 2010 | 04:55 PM
YzRider452's Avatar
Nope, just slightly larger and smoother on the intake ports, and a perfect gasket match and port smoothing on the exhaust.
Old Feb 21, 2010 | 09:29 PM
euthanasia's Avatar
If you don't have any micrometers or snap gauges to measure in side the runners. I wouldn't even try to do any real porting.
Old Feb 22, 2010 | 12:29 AM
Frew's Avatar
instead use this guy, great prices, port jobs look f'in great
Old Feb 22, 2010 | 04:49 AM
ralliartist's Avatar
this won't end well.
Old Feb 22, 2010 | 10:28 AM
Omnigear's Avatar
read ur visitors msg, since ur inbox is full
Old Feb 22, 2010 | 10:36 AM
Frew's Avatar
Im waiting for john to see this thread, lolz
Old Feb 22, 2010 | 01:38 PM
cakeeater's Avatar
You're assuming he would know what to do with them if he had them
Old Feb 22, 2010 | 01:55 PM
qwikredline's Avatar
X 2 FAIL etc
Old Feb 22, 2010 | 02:22 PM
YzRider452's Avatar
Damn this turned nasty quick. Sorry this isnt ur average question about what springs to use, or why is my car squeaking. I have all the tools required for this, and i do have knowledge on head porting. All the heads ive ported have been iron. So enough of the smart ass comments, save ur baby dick syndrome for the next guy who asks how much power a stage 2 kit puts down.
Old Feb 22, 2010 | 03:43 PM
you asked for tips, dont get butthurt when the answers are not what you expected. I ported heads in high school for a job. I would not port heads now, it is PRACTICALLY impossible short of copying a CAD profile from GM to come close to their expertise/knowledge.
Tip: if you port the inlet, it will probably hurt the head performance.
Tip: if you dont machine the head face properly, the head will probably not do well for long
Tip: if you port the exhaust, you will likely do one of two things: A) port too much and hurt flow B) port too little and gain no improved flow.
Tip: if you dont do a 3 axis valve seat/face rework, the sealing will not be optimum.
etc. do a search. The head flowbench results are around...good luck
Old Feb 22, 2010 | 04:04 PM
YzRider452's Avatar
Im not butt hurt at all. Like i said before ive had experience with this, just figured id post for tips. Im not going to be touching the valve seats at all, and i will be flow benching before and after. Ill be sure to post up the results.
Jan 12, 2016 12:01 AM
Oct 13, 2015 09:32 PM
Trav3480
Oct 1, 2015 08:17 PM
Sep 27, 2015 08:53 PM
