header to catback ?
Old Dec 2, 2010 | 12:41 PM
joeyc's Avatar
header to catback ?
hey guys i was just wonderin if anyone knows if the zzp header will bolt up to the megan racing cat back. sorry if this isnt the right forum to post this. i did do a search but nothin came up. thanks.
Old Dec 3, 2010 | 04:32 PM
Black Napkin's Avatar
i think the header has to connect to the down pipe first and then the down pipe is connected to the exhaust. if u have a stock down pipe then the outlet to the header needs to be 2.5in. then the outlet to the down pipe needs to be 2.5 in. idk if u are getting the long tube headers. but maybe this will help. this is for the long tube- "3 inch weld in" will be a full length downpipe, that you will have to weld up to a custom cat back exhaust. The "Bolt in" option will come with an exit flange that will bolt up to a stock cat back exhaust or most 2.25" to 2.5" cat back exhaust systems. The '3 inch bolt in for ZZP cat back" will bolt up perfectly to our 3" cat back exhaust" this is from zzp
goaliemo
Sep 28, 2015 01:37 PM
09SSlow
Sep 28, 2015 12:37 AM
z28addiction
Sep 28, 2015 12:03 AM
