header/dp sound question
I know that header/dp combos can add some hp. I'm getting ready to do a stage 2 upgrade, and I know that header/dp will help, but I hate the way a lot of the exhausts sound. Do the header and dp change the sound of our exhausts drastically? I mean, will it be much louder? Thanks in advance!
That's what I was thinking. The header/ dp and then gmpp. That wouldn't be too loud, right? One other question, would I need to install all at once? I have a stock cat so would putting the header/dp cause problems with that, or do I just need to put it on all at one time? Thanks a lot guys. Still new at this stuff! I appreciate all the advie!
Your dp will have a high flow cat on it if you order one with a cat. And to answer your question, no you don't have to install it all at once. You can install which ever one you decide to do first. I have heard a few cars with GMPP exhausts w/header/dp setups and they are kind of loud but not as bad as a mangnaflow, vibrant, or meagan catback would be with a header.
i'm just gettin the zzp downpipe with a high-flow cat welded on it and then a megan cat-back.. personally i dont see any big reason to get the headers, their only goin to add like 5hp.. i'm takin the extra $300 i was goin to spend on that and spend it on a cxracing heat exchanger
i dont know i dont see it give much more then 5hp IMO... plus i think the heat exchanger looks 20 times better on and will add more hp... i'll end up buyin a zzp shorty header later in may or somethin
DANRICKARD
Oct 1, 2015 12:08 AM
