header/dp sound question
Old Apr 12, 2008 | 10:47 PM
06YellowSS/SCinSC's Avatar
I know that header/dp combos can add some hp. I'm getting ready to do a stage 2 upgrade, and I know that header/dp will help, but I hate the way a lot of the exhausts sound. Do the header and dp change the sound of our exhausts drastically? I mean, will it be much louder? Thanks in advance!
Old Apr 12, 2008 | 10:50 PM
stealthy1ss's Avatar
They make the car a little bit louder. My question for you is do you have an aftermarket catback or are you stock?
Old Apr 12, 2008 | 10:51 PM
Sunburst_SS's Avatar
yea, the header and downpipe will change it a little....even more if you eliminate the cat. The real sound change will come with a cat-back exhaust
Old Apr 12, 2008 | 10:52 PM
blk ss/sc 1's Avatar
if you dont like the real loud exhaust my advice for u would to just get the gmpp touring and if you want the extra HP get the zzp header/dp
Old Apr 12, 2008 | 10:56 PM
I have the ZZP Midlength combo with a stock catback and it sounds pretty good but not loud.
Old Apr 12, 2008 | 10:57 PM
That's what I was thinking. The header/ dp and then gmpp. That wouldn't be too loud, right? One other question, would I need to install all at once? I have a stock cat so would putting the header/dp cause problems with that, or do I just need to put it on all at one time? Thanks a lot guys. Still new at this stuff! I appreciate all the advie!
Old Apr 12, 2008 | 11:01 PM
you don't need to put them all on together..you can do it in pieces. The GMPP exhaust has a nice tone to it....not to loud, but louder then stock
Your dp will have a high flow cat on it if you order one with a cat. And to answer your question, no you don't have to install it all at once. You can install which ever one you decide to do first. I have heard a few cars with GMPP exhausts w/header/dp setups and they are kind of loud but not as bad as a mangnaflow, vibrant, or meagan catback would be with a header.
Old Apr 12, 2008 | 11:12 PM
i'm just gettin the zzp downpipe with a high-flow cat welded on it and then a megan cat-back.. personally i dont see any big reason to get the headers, their only goin to add like 5hp.. i'm takin the extra $300 i was goin to spend on that and spend it on a cxracing heat exchanger
Old Apr 12, 2008 | 11:15 PM
I beg to differ on only seeing 5hp of difference with a header.
Old Apr 12, 2008 | 11:16 PM
Coolbalt SS's Avatar
they may only give 5 hp but they will make it easier to get more hp outta other mods
Old Apr 12, 2008 | 11:28 PM
i dont know i dont see it give much more then 5hp IMO... plus i think the heat exchanger looks 20 times better on and will add more hp... i'll end up buyin a zzp shorty header later in may or somethin
turbochargedss2012
Sep 20, 2023 12:17 PM
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
jimbofug007
Oct 2, 2015 12:06 PM
DANRICKARD
Oct 1, 2015 12:08 AM
