header question?
header question?
i installed my header yesterday and wanted to know if its ok if the header is touching the bar underneath where the coolant travels? my friend which is a tech said it was ok but i wanted someone elses opinion
It will cause a vibration that could damage the coating on the header (if there is one). It will probably be very annoying. I would talk to who ever you got the header from and see if it is a flawed part or if you need to look for another header. Which header is it?
i had to heat treat and form my ca header to fit properly, the vibrations may also cause the header to push against the coolent pipe and cause it to leak. you can rotate the pipe with no fit issues also.
when you take off the header....you can just rotate the coolant pipe by hand so that the little arc in the pipe that the header is pressing against is facing the other way....thats the easy way to fix it.
the only thing i kan think of is when u hit a hard bump that the pipe may rotate and slip on the the header...but i dont c that happening....but you shouldnt have any problems......like i said, mines been heat treated and formed so i have 0 issues. you should be ok
z28addiction
Sep 28, 2015 12:03 AM
