header question?
Old Apr 7, 2007 | 01:48 PM
supermantxz24's Avatar
header question?
i installed my header yesterday and wanted to know if its ok if the header is touching the bar underneath where the coolant travels? my friend which is a tech said it was ok but i wanted someone elses opinion
Old Apr 7, 2007 | 02:42 PM
Cobalt_Supercharged's Avatar
It will cause a vibration that could damage the coating on the header (if there is one). It will probably be very annoying. I would talk to who ever you got the header from and see if it is a flawed part or if you need to look for another header. Which header is it?
Old Apr 7, 2007 | 05:39 PM
its the cobalt-addiction one
Old Apr 7, 2007 | 05:52 PM
I would contact Kenny at CA or Paul (06blackg85ss) about it and see what they have to say.
Old Apr 7, 2007 | 05:58 PM
MISSMATCHEDFACES's Avatar
i had to heat treat and form my ca header to fit properly, the vibrations may also cause the header to push against the coolent pipe and cause it to leak. you can rotate the pipe with no fit issues also.
Old Apr 7, 2007 | 06:11 PM
blueta's Avatar
I don't know how sensetive these cars are to noises, but could also create some fasle KR which will hurt performance.
Old Apr 8, 2007 | 01:02 AM
i just found out im leaking coolant. what do you mean "you can rotate the pipe with no fit issues also"?
Old Apr 8, 2007 | 09:44 AM
when you take off the header....you can just rotate the coolant pipe by hand so that the little arc in the pipe that the header is pressing against is facing the other way....thats the easy way to fix it.
Old Apr 8, 2007 | 10:30 AM
ok i will do that thanks guys
Old Apr 8, 2007 | 10:32 AM
no prob
Old Apr 8, 2007 | 01:33 PM
one last question is it ok if the header is touching the coolant bar (will it damage it) if the bar isnt leaking anymore?
Old Apr 8, 2007 | 02:00 PM
the only thing i kan think of is when u hit a hard bump that the pipe may rotate and slip on the the header...but i dont c that happening....but you shouldnt have any problems......like i said, mines been heat treated and formed so i have 0 issues. you should be ok
Old Apr 8, 2007 | 02:08 PM
ok thanks
brandon04
Oct 21, 2015 07:04 AM
Extremespeed
Sep 29, 2015 04:34 AM
goaliemo
Sep 28, 2015 01:37 PM
z28addiction
Sep 28, 2015 12:03 AM
