Heat Exchanger And Installing It!!!!!???
Old Oct 29, 2007 | 08:22 PM
Johnboy12358's Avatar
I think you can use it inline no problem. That will also increase the volume of water that you have in the system which will help with heatsoaking...
Old Oct 29, 2007 | 08:23 PM
distillion's Avatar
ya, you use it inline, a few people have done this.
i plan on doin that with mine.
Old Oct 29, 2007 | 08:25 PM
lnf08ecotec's Avatar
k, anyone done it and can tell about it like with a diagram....drawn a lil better than shortbus'...or maybe some mounting ideas......do i have to drill anything?...does anyone have a diagram?.......
Old Oct 29, 2007 | 08:28 PM
ItalianJoe1's Avatar
I have mine mounted inline. If you have the C/A brackets, you just drill 2 3/8" holes in the bumper and install the brackets, done up there. Remove the hose going from the I/C pump to the bottom of the stock H/E, and plug one of the hoses from the new H/E onto the two places you just opened up. Re-fill with coolant, and let it bleed out the air for the next few days, and you're done. Really simple, one of the easiest mods I've ever done and it looks great. Just make sure that you put something in the bumper where you drill, at least some primer or something, so it doesn't rust.
Old Oct 29, 2007 | 08:33 PM
Thanks, Joe! lol, why is it that you're always the one helping around here?......
Old Oct 30, 2007 | 03:39 AM
Because I do all the work myself and I like to help people? I don't know really. I just try to make life easier on everybody. I ask for help when I need it, and I like to help where I can.
Old Oct 30, 2007 | 04:03 AM
06' SS2SS's Avatar
Here's a good thread to check out if you are still having trouble.
https://www.cobaltss.net/forums/show...heat+exchanger
Old Oct 30, 2007 | 03:28 PM
k, question to anyone that knows: on the CA heat exchanger the "in" side is the top part; correct? Or is that the "out". Which is it...is the bottom line the in or out? Tell me if the image below is correct or backwards......?
Old Oct 30, 2007 | 03:36 PM
Honestly, I dont think it matters. The fluid is going to run through twice either way. It will either start on the top and end on the bottom or vise versa...
Old Oct 30, 2007 | 03:44 PM
Johnboy; so this is an acceptable way to do it(?):
Old Oct 30, 2007 | 04:06 PM
  #36
I think this is how it should go. Again, I dont have this installed, so I am only hypothesizing...
Old Oct 30, 2007 | 06:53 PM
  #37
That's the right configuration.
As far as the in/out on the top or bottom of the CA H/E, it doesn't make a difference. I did mine in on the top, but it is the same thing either way.
Old Oct 30, 2007 | 08:57 PM
  #38
Here ya go guys...the "almost finished" product...just have to get air out of the system and I'm done..like my stencil I put on there.......
Old Oct 30, 2007 | 09:42 PM
  #39
2K5SS/SC?'s Avatar
Looks great! I need to get one too.
Old Oct 30, 2007 | 10:51 PM
  #40
I like that stencil, whered you get that?
Old Oct 30, 2007 | 11:30 PM
  #41
Very nice. I don't really like the writing on the H/E's that i've seen, but it still looks good.
Old Oct 31, 2007 | 12:40 PM
  #42
I made it...printed a picture of an SS emblem off the web, cut the SS out of the paper, and then used a glue stick on the back of the paper (no residue) to make sure the thin piece of paper would stay in place and not lift up when painting (to prevent over spray) and masked off the rest...........I love how it came out....I was weary, bc I was like, watch me spend $300 on this heat exchanger and fk* it up when I paint the stencil but it came out great........
Old Oct 31, 2007 | 12:42 PM
  #43
distillion's Avatar
been waiting for mine since june.
i cant help it get a lil mad while reading this thread.............
looks great, good job.
DarrenGC
Dec 24, 2021 01:55 PM
dennis69
Oct 20, 2015 07:39 AM
justinchinn
Oct 2, 2015 12:18 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
