Heat Exchanger needed?
Old Feb 6, 2008 | 04:26 PM
kenhebe's Avatar
Will I be doing any harm running my 2.9 without a front mounted heat exchanger, or do I need to install it now.
Old Feb 6, 2008 | 04:28 PM
Drakonen2000's Avatar
hey man, what kind of numbers are you running...i am looking at getting the exact same setup you have (with a few minor modifications)...and where did you get it all installed?
EdCobaltSS's Avatar
I've Been Running A 2.9" Pulley Without A Front Mount For Almost A Year Now, And No Problems
Old Feb 6, 2008 | 04:32 PM
Dayta's Avatar
im running a 2.8 with 60s and a tune
will that do some damage ifi dont get one?
Old Feb 6, 2008 | 04:33 PM
Raven SS's Avatar
i believe lsjwannabe is running a 2.5 without a h/e...
Old Feb 6, 2008 | 04:38 PM
kenhebe's Avatar
I haven't gone to the dyno yet, so I do not know. I manage Pro Care Collision in Flower Mound, TX and with the exception of the Stage II kit, I had the rest of the stuff installed by one of my techs.
splitimage's Avatar
are you stupid? your car has one, its an UPGRADE.
you think the ss/sc comes without a front mounted? LEWL
Old Feb 6, 2008 | 04:39 PM
dude...u wanna help me out??? i will pay for the labor, no biggie, but i just need a good reliable place to take it for all the stuff as it comes in!
...im plannin on gm stg 2, a zzp header / dp w/cat, corsa touring, dual pass plate with secondary resivuar, stg 3 clutch, spec flywheel, a 2.8, and some misc guages! ...and i have a key scratch from some douchebag in my right rear quarter, i need to get that removed...
Old Feb 6, 2008 | 07:03 PM
splitimage's Avatar
YOUR CAR HAS A FRONT MOUNTED HEAT EXCHANGER, ITS RIGHT INFRONT OF YOUR RAD.
the mod with the cobra heat exchanger is an UPGRADE.
Old Feb 6, 2008 | 07:05 PM
an0malous's Avatar
do you NEED it?
no.
will it help? yes.
Old Feb 6, 2008 | 07:07 PM
SBcobalt's Avatar
does anyone have the ca front mount heat exchanger? how much does it help compared to stockk?
Old Feb 6, 2008 | 07:10 PM
an0malous's Avatar
just so you all know, when people do the H/E mod....you arent replacing the stocker with a different HE
your ADDING another H/E in series with the stock one.
the addition of all the extra cooling fins, as well as extra coolant, combines for a very effective cheap mod.
Old Feb 6, 2008 | 07:12 PM
KillerBee's Avatar
No harm but having it will help a lot with cooling i recomend devils own meth injection kit instead though help with cooling 50xs better
BlilBT's Avatar
Any time you are spinning the Super faster than GM Does you should be thinking of upgrading the Cooling system. Will you notice with a butt dyno NO>>> But will you notice if you are racing 1 right after another or just driving around the car retains more Constant HP Yes! I have been on a dyno 2 differnt times for a total of 7 pulls done back to back at 87 degrees & The car never lost more than 3 hp to Heat soak! Actually my 3rd pull on the 1st Visit was my strongest!
Old Feb 6, 2008 | 07:13 PM
splitimage's Avatar
you silly goose, you need to tune methanol...
Old Feb 6, 2008 | 07:14 PM
KillerBee's Avatar
Well i know that haveing meth will cool you much better though just giving my opinion
Old Feb 6, 2008 | 07:17 PM
splitimage's Avatar
yes, drastically, but for it to run you need a hp tune!!!!
Old Feb 6, 2008 | 07:23 PM
KillerBee's Avatar
yeah but i am sure if he wanted to some one around him has hp tuners
Old Feb 6, 2008 | 10:55 PM
2K5SS/SC?'s Avatar
It's not necessary to tune for the meth kit for it to run. If you use a small jet, you can just use it cooling principles/minor octane booster.
If you use a correct sized jet and tune for it by adding some more timing, more power can be had for sure.
To the OP, the dual pass mod would be perfect for your setup at the moment. Then the Devil's Own Meth kit after that, followed by the front mount HE.
Old Feb 6, 2008 | 11:08 PM
blownredSS's Avatar
Does someone have a link to explain what the heck a Water/Meth injection kit does, how it works? I know what a dual pass does, and how it works, same as a H/E, but how does the injection work?
Old Feb 8, 2008 | 07:06 PM
kenhebe's Avatar
I know that. I was simply asking if I needed the front mounted one right now, or if I could wait a little bit.
DarrenGC
Dec 24, 2021 01:55 PM
agentirons
Oct 16, 2015 02:11 AM
n20saturn
Sep 30, 2015 12:26 AM
Iceberg
Sep 29, 2015 12:33 PM
jmelton327
Sep 26, 2015 10:04 PM
