Heat exchanger question
Old Feb 22, 2010 | 01:21 PM
danieluf's Avatar
I installed the zzp stage 3 heat exchager yesterday and everything went smoothly but when I checked today I found that one of the hoses I installed is bent in two places. It doesn't seem to be too bad but if the hose was pinched off what would happen? Just a little paranoid I guess.
Old Feb 22, 2010 | 01:45 PM
blackbolt89's Avatar
you would probably have noticed your IATs and coolant temp skyrocketing, no?
Old Feb 22, 2010 | 01:47 PM
qwikredline's Avatar
bent hose= no good
Old Feb 22, 2010 | 02:54 PM
danieluf's Avatar
My temps are low so I dont think that it is pinched. I moved the hoses around to loosen them up anyway.
I am running a 2.8 with the GM stage 2 tune until I get the zzp tune so I can install 60 lb injectors.
IAT2's only went as high as 135 at wot so im not too concerned
Old Feb 22, 2010 | 02:57 PM
Staged07SS's Avatar
Administrator
Administrator
Bad idea ....
Old Feb 22, 2010 | 03:03 PM
danieluf's Avatar
Im putting on the 60lb injectors tomorrow with the zzp tune. running the 2.8 on the stage 2 tune will be fine until then
Old Feb 22, 2010 | 04:11 PM
YzRider452's Avatar
Put a 90 degree fitting in there, Bent hoses slow down the coolant flow.
Old Feb 22, 2010 | 04:46 PM
Staged07SS's Avatar
Administrator
Administrator
as long as you're doing it soon, and you don't do any wide open throttle runs ....
Old Feb 22, 2010 | 06:02 PM
BlackJackSS's Avatar
why...? jw what you think will happen.
Old Feb 22, 2010 | 06:08 PM
elite_Cyborg's Avatar
lol .
Old Feb 22, 2010 | 06:10 PM
glen229's Avatar
fail, gmstg2 on a 2.8 lolz
Old Feb 22, 2010 | 06:49 PM
Staged07SS's Avatar
Administrator
Administrator
Do you really have to even ask ?? Look it up, and find out why it's not smart (at all) to run a 2.8 on a GM Stage Tune. I'm not being an ass, I'm just so sick of seeing people on here doing stupid things to their cars. Get all the proper supporting mods on a car before you start trying to pulley down.
Old Feb 22, 2010 | 06:58 PM
Well if it hurts my car any I guess my dealership will be buying me a new motor. Bc they sold my car to me like that. I know u need a cooling mod to run a 2.8 anyways. Which I now have. But u never had any major problems besides power being robbed bc of the heat. My 3 dynos r truely a fail lol...u act like it's the end of the world, but it's not.
Old Feb 22, 2010 | 07:28 PM
Dead Zen's Avatar
it will be the end of the world with zzp parts.
Old Feb 22, 2010 | 07:45 PM
Staged07SS's Avatar
Administrator
Administrator
Well, your dyno numbers show that the 2.8 is hurting you running it on a GM tune. A properly tuned 2.8 car, running the proper supporting mods usually puts down 255+whp and 235+wtq. Your low torque shows that the GM Stage Kit is more than likely pulling timing. Prob. due to the fact you had no cooling mods, and your IPW/IDC's are off the charts. Hey, it's your car, if you think running the 2.8 is ok on a unmodified GM Stage Tune, more power to you .... but you will see better numbers, and your car will run better with the right tune/injectors.
Cliff Notes on what is wrong with your setup:
1. 2.8 on a GM Stage Tune (unmodified)
Old Feb 22, 2010 | 07:59 PM
trey ss's Avatar
DAMN! thats cold
DarrenGC
Dec 24, 2021 01:55 PM
brandon04
Oct 21, 2015 07:04 AM
n20saturn
Sep 30, 2015 12:26 AM
Extremespeed
Sep 29, 2015 04:34 AM
jmelton327
Sep 26, 2015 10:04 PM
