Heat Exchanger Question - Help pease
Old 11-15-2007, 03:44 PM
QuikSilverSS's Avatar
I am getting a CA Heat exchanger and I was wondering if it is better to just replace the stock heat exchanger for the CA one, or just run both heat exchangers? Which do you feel would drop the IAT2 temps more? I was told that it may be better to run both becuase of the additional volume of coolant with both heat exchangers? I also am getting the GMPP dual Pass option B and wondered if 2 heat exchangers are needed when I plan on running the dual pass anyways?
I also plan on running approx 60% dexcool, 40 % water (distilled) and a bottle of water wetter.
I could use some advice?
anyone?
Last edited by QuikSilverSS; 11-15-2007 at 03:44 PM. Reason: Automerged Doublepost
BlilBT's Avatar
Here check out this Link & Yes you get more Cooling By having 2 H/E The Diagram on the 3rd page is how it sets up.
I'm running straight Distilled water & Redline Water wetter!
https://www.cobaltss.net/forums/show...t=76981&page=3
Old 11-15-2007, 04:11 PM
Rent me! per hour
Area47's Avatar
if the temps drop below 32 degree's. it is not wise to run straight water.
Old 11-15-2007, 04:19 PM
BlilBT's Avatar
LOOK at My Location>> LOL, We never see below 42 degrees. It snowed once here in 1979 & didn't even make it to the Ground!
Old 11-15-2007, 04:21 PM
SSdan's Avatar
Rub it in why don't ya!
Old 11-15-2007, 04:22 PM
It does go below freezing here in canada, I think that running 60/40 dexcool/water should be alright, i am also going to be running water wetter with this mix. Is this better for IATs then just running straight dexcool? Or should I adjust the mix even more (ie. 50/50 d/w or 40/60 d/w) ??
Old 11-15-2007, 04:25 PM
Rent me! per hour
Area47's Avatar
im fully aware of that. not everyone is smart enough to notice that. then again, most people don't know where rhode island is either.
Old 11-15-2007, 04:26 PM
SSdan's Avatar
The middle of the Atlantic Ocean duh!
Old 11-15-2007, 04:33 PM
BlilBT's Avatar
Old 11-16-2007, 09:11 AM
IS it better to run 100% dexcool or run a combo of dexcool/water (i.e. 60/40, 50/50, 40/60 etc) for lower IAT2's with the dual pass option B and CA Heat exchanger????
Anyone?
Last edited by QuikSilverSS; 11-16-2007 at 09:11 AM. Reason: Automerged Doublepost
Old 11-16-2007, 09:15 AM
SSdan's Avatar
Combo. As you know, water is the best property to cool a motor down safely. But water freezes, so what the dexcool/antifreeze does is raises the freezing point of the water and in return water raises the boiling temp of the dexcool/antifreeze.
The only time you run 100% water is when you live where it doesn't get under freezing.
Old 11-16-2007, 09:21 AM
Ok so what percentage of dexcool to water than for a climate that is freezing 4 months of the year? can I get away with 40% dexcool 60% water? Plus add redline water wetter??
Old 11-16-2007, 09:23 AM
SSdan's Avatar
IMO run a 45% dexcool 45% water and 10% water wetter
Old 11-16-2007, 09:43 AM
DoMiStIc_RuSh_06's Avatar
Hey, way off topic but when you put your zex plugs in, did you have to gap them???? If so, what did you gap them????Sorry about being off topic
Old 11-16-2007, 09:44 AM
I appreciate the input, I think I would run 2 bottles of water wetter and like a 45/55 mix of dexcool/water
Anyone else have some advice?
Old 11-16-2007, 09:45 AM
Edubs's Avatar
I thought the ZEX were pre-gapped and you shouldn't mess w/ it...
Old 11-16-2007, 09:46 AM
No they are pre gapped, just put them right in, the best plugs in my opinion, I have used many sets of NGK BKR7E's at differnt gappes (0.040, 0.035, 0.032, etc..) and the ZEX are the best by far
Edubs's Avatar
I'm pretty sure stock is 50/50 dex/wat. You should be fine w/ one bottle of water wetter and 45/45...
Old 11-16-2007, 09:48 AM
Really i didnt know that I thought the intercooler coolant was 100% dexcool just like in the rad?
Old 11-16-2007, 09:53 AM
SSdan's Avatar
Any car manufacturer would be completely idiotic to put 100% of ANYTHING to cool the car down.
Old 11-16-2007, 09:58 AM
Edubs's Avatar
No, the dexcool in the rad is also 50/50 mix from GM. If you go to Autozone or something, you'll see that they sell it both straight dexcool, or pre-mixed 50/50 for convenience...
Old 11-16-2007, 10:12 AM
Thanks guys, I think that I will just add distilled water and some water wetter than, when adding additional fluid for the dual pass and the CA Heat exchanger.
DarrenGC
12-24-2021 01:55 PM
brandon04
10-21-2015 07:04 AM
n20saturn
09-30-2015 12:26 AM
Extremespeed
09-29-2015 04:34 AM
jmelton327
09-26-2015 10:04 PM
Quick Reply: Heat Exchanger Question - Help pease
