Help...
Old Jan 30, 2013 | 08:38 PM
cuebalt's Avatar
Help...
In short.. When i try to go past around half throttle my car dies for a sec (or completely), then bursts to life again. If i stay below half throttle then everything is fine. I've tried cleaning the MAF sensor, throttle body, filter and any sensor i could see but its just made it worse.
It started happening a little while after (not right after) i did 60lb injectors, 2.8 pulley, option b, dual pass, heat exchanger and tune (trifecta) also i have an injen.
here's a kinda crappy video i took, for the first 3/4 of the video i'm just tapping the throttle to half or so and at the end i'm pushing the throttle maybe 20-25% and it revs just fine
Old Jan 30, 2013 | 08:41 PM
574's Avatar
574
I'm gonna go with a clogged cat
Old Jan 30, 2013 | 08:46 PM
cuebalt's Avatar
i've got pretty much a brand new zzp dp, i did hear some weird noises coming from it today though haha
Old Jan 30, 2013 | 09:13 PM
574's Avatar
574
Well it's not the cat then if its new
Old Jan 30, 2013 | 09:23 PM
BankerBalt's Avatar
probably in the tune. you're not throwing any codes at all?
Old Jan 30, 2013 | 09:34 PM
cuebalt's Avatar
Im not gonna rule the cat out, easy to check and no, no codes
Old Jan 30, 2013 | 09:37 PM
BankerBalt's Avatar
what do your afr's look like when you go past half? does it just run rich as hell? cuz it could be flooding the combustion chamber
Old Jan 30, 2013 | 09:52 PM
cuebalt's Avatar
Yes it does, i took another video, just uploading now. Could the injectors be faulty?
Old Jan 30, 2013 | 10:04 PM
Powell Race Parts's Avatar
make sure the connector to the throttle body is plugged in properly AND the grey safety lock clip is in place.
my .02 c
Old Jan 30, 2013 | 10:16 PM
cuebalt's Avatar
yeah, did that john. If i can add, it did seem to get worse when i cleaned the maf and throttle body
here's the other video:
sound came out a little weird, when it does rev it sounds normal
Old Jan 30, 2013 | 10:58 PM
Infernokron's Avatar
My best guess is something in the tune. When I switched to 80's this last summer my car started doing something like this, especially in first. Part throttle was fine. I had *way* to much fuel in the tune, pulled a bunch out and it runs great.
Almost wonder if maybe they tuned it for #42's by accident? Just another thought.
Old Jan 30, 2013 | 11:00 PM
cuebalt's Avatar
I've tried contacting bnr in the past about this same issue and all they told me was to get it looked at... no help. the weird thing about it is it didn't start happening till a couple weeks after i got my tune/60's and its trifecta so i have no god damn clue what the tune's set up for lol
Old Jan 30, 2013 | 11:15 PM
Did the weather change?
Old Jan 30, 2013 | 11:20 PM
cuebalt's Avatar
yes it did happen after it started raining a lot more and my maf was soaking wet today but I've dried it off and cleaned it and it didn't seem to help
Old Jan 30, 2013 | 11:33 PM
I wasn't thinking about the MAF getting wet but that could be it. Big changes in temperature can throw your AFR off enough to do something like this. As a side note on rain, my car hates the humidity (don't think my MAF is getting wet, just a picky car).
If you haven't checked the cat yet I would at least pull and check it, easy and free. Your wide-band is showing really rich, that's a big part of why I'm thinking it's the tune. If BNR told you to get it looked at ask them if they'll cover the shop cost etc. for diagnostic. My bet's still on the tune. If the company that made it isn't interested in trying to help you troubleshoot then your kinda stuck.
These cars can run speed density as well (they ignore the MAF). If you un-plug the MAF the car should still run and should run more or less normal. That's an easy test to eliminate a bad MAF. I wouldn't drive the car a lot like that though without being able to log it.
Old Jan 30, 2013 | 11:38 PM
cuebalt's Avatar
ya its my dd which sucks, but I'm gonna try and take the day off tomorrow and just go over everything i can think of. I don't have the trifecta cord needed either since the black box style cords are hard to come by, i had to borrow one which really sucks
Old Jan 31, 2013 | 04:13 PM
cuebalt's Avatar
Bump, its not the cat and the car just starts up and dies after a couple seconds when the maf is disconected
Old Jan 31, 2013 | 07:56 PM
I've always failed the MAF through the computer, maybe unplugging it is different. My Balts put up for the winter so I can't test this :-/. If its not the tune the only other things I can think of is a boost or intake leak, bad MAF, or maybe a bad injector.
Short of finding someone to log and check the tune I don't know any way to check it. I hate just throwing money at a problem but a new MAF might be the next step. Check what the boost gauge is doing when your giving it throttle, that's my best guess for how to check for a boost leak. I'm betting someone else has a better method, would be worth searching on that one. If its a bad injector I don't know of any easy way to check that either (think changing back to stock pulley/injectors/tune or buying new injectors :-/)
Old Jan 31, 2013 | 09:27 PM
cuebalt's Avatar
I pulled the maf again and it was soaked again, the day after i had pulled it the 1st time. I ordered a new filter because my current one is sopping wet, i think that may be the problem.
Old Jan 31, 2013 | 09:36 PM
574's Avatar
574
Put stock air box back on for the wet season if you have to
Old Jan 31, 2013 | 10:36 PM
cuebalt's Avatar
"Wet season" is year round in bc lol
Old Jan 31, 2013 | 10:41 PM
stay stock. thats your answer. i do, no problem for power
Old Feb 1, 2013 | 12:05 AM
cuebalt's Avatar
Ya i should have, ah well. I ordered a new filter and i'll get a hydro shield, might fab up a water guard while im at it just to be sure
Old Feb 2, 2013 | 06:57 PM
cuebalt's Avatar
FIXED, it ws the wet filter soaking my maf causing the problem. Dried the maf and bought a new filter and all is well... feels good man
LinzColbalt
Jul 21, 2010 06:03 PM
Mike_peperni
May 25, 2010 06:15 PM
Soulflyz
May 18, 2010 04:28 PM
pantherqs
Apr 25, 2010 12:26 PM
