Double Door, Turn Signal Chime?
Old May 9, 2010 | 01:23 PM
Soulflyz's Avatar
Hello there,
I have just installed a Alpine IVA-505 in my Cobalt SS/SC 2006
I Used The Scosche GM13SR 2004-08 GM LAN 11 Bit Stereo Replacement Interface
and a PAC TR7 override for my video (i used this item in my 03 tiburon should be fine).
Since i have done the install my Door chimes and truning signal click or beep twice, just off timeing of eachother, the fist click or beep is normal but the second one sounds alot different.. kinda like a hot girl warring long heels walking down a school halway.
yah i know i bit grafic but its very iritating and have no real idea what the issue is.
I Have looked throught many of the theads and have found no info on this error.
Thanks for any help...
Old May 9, 2010 | 04:07 PM
Spun's Avatar
I think that the 2007 and up use the left front speaker for chimes.
Since your is a 2006, I think you have a chime box.
So if I had to make a guess the first chime is the one coming through you chime box, and the second one is being generated by the Scosche GM13SR and sent to the left front speaker.
As to how to solve the issue, other than running your fronts off an aftermarket amp, IDK
Old May 9, 2010 | 06:14 PM
Soulflyz's Avatar
I have an after market amp but factory speakers, but i am going to swap them on monday.
Old May 10, 2010 | 01:55 AM
EmperorJJ1's Avatar
if you have an 06 the chimes come from what i think is the speedometer.... or in that general area. anyway you dont need a chime replacement box. the easiest fix would be to buy the cheap harness and run ur acc wire and sell the module harness u bought to someone else
Old May 10, 2010 | 02:40 AM
Spun's Avatar
When I said chime box I was talking about the stock one, where ever it is located. What I was getting at was there are 2 chimes being generated, one being the stock one and by the Scosche unit. Both of which are not coming at the same time.
OP- You have an aftermarket amp running the stock speakers? Or do you have an aftermarket amp runing a sub in the trunk?
Old May 10, 2010 | 02:53 AM
EmperorJJ1's Avatar
right spun... u got it right. i was just saying when i had the dash off and just the speedo chillin thats where i think the stock chimes were coming from
Old May 10, 2010 | 04:27 AM
Soulflyz's Avatar
I have a sub and speaker amp installed, i have replaces the back speakers and sub and going to replace the fronts on monday.
Sorry for the late replay was at work.
Old May 11, 2010 | 02:29 AM
EmperorJJ1's Avatar
if the module u have makes the 2nd chime via the speakers then that will fix it. if it has its own little speaker in it then u might be fucked
Old May 13, 2010 | 04:41 PM
curtis0432's Avatar
try turning the module off then see if everything works good. If it does than you wont have to buy another harness.
Old May 18, 2010 | 04:28 PM
scosche's Avatar
Before connecting a stereo wiring Interface (such as the GM13SR) intoa GM vehicle, it is necessary to follows these steps:
1) Close All Doors
2) Turn Off All Lights
3) Remove Keys from Ignition
4) Wait for 2 minutes (for vehicle's data-line to settle)
5) Connect Interface into Vehicle
6) Start the Vehicle
7) Test the Radio
This procedure is necessary for the proper functionality of the GM wiring interface.
06MetallicBalt
Jul 20, 2025 08:47 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Tupp
2.2L LAP Performance Tech
Jan 2, 2016 12:04 PM
roth
Sep 26, 2015 12:16 PM
