Help!!!
Old Apr 5, 2013 | 10:21 PM
Mendomar06's Avatar
Help!!!
I am about to rip my hair out
So me car just died on me, did a hard pull in first, wot in second, let off throttle and put in fifth and coasted down to about 60mph, slightly depressed throttle to keep speed at 60mph as soon as I did that the check engine light came on and the DIC said Engine power reduced, I pulled over and checked my interceptor gauge and it read these codes
P0017
P0102
P0340
P0352
P0068
(BTW as soon as I pulled over the engine died)
I tried to start it again and nothing, I cleared the trouble codes and still nothing, I pulled the car home, I've got it in the garage with the valve cover off, timing seems to be spot on what the heck could be going on??
Old Apr 5, 2013 | 10:50 PM
rivaladore's Avatar
Check your fuses, check your harness connections, and check all the grounds. Could possibly be bad throttle body or camshaft sensor crapped out
Old Apr 5, 2013 | 11:24 PM
Mendomar06's Avatar
Motherfu*ker I can't enjoy my car one weekend?!
Old Apr 6, 2013 | 12:12 AM
rivaladore's Avatar
Any luck yet? Have any friends with cobalt that you can swap throttle bodies and sensors really quick? That would make troubleshooting so much quicker. Maybe post in the WA regional thread and see if there's any local lsj guys that would let you swap out a known working part just so you get it right the first time
Old Apr 6, 2013 | 12:38 AM
Squints's Avatar
Unplug your ecu wait two minutes and plug it back in it'll clear the engine disabled code. Once that code comes up it wont let the engine run until it is enabled. I had to do it to mine. Blue plug on ecu in front of the fuse box under the hood just in case you dont know didnt want you to come back and have to ask.
Old Apr 6, 2013 | 03:13 PM
Mendomar06's Avatar
Ok as of right now im in the middle of pulling off the timing chaing cover because me dumb a** dropped a bolt down there and I cant get it out, car sat all night with the battery unplugged and as soon as I can get it all put together I will let you know, some one said that it could be the crankshaft position sensor that can be going or has gone bad, should I replace it?
Old Apr 6, 2013 | 08:29 PM
Mendomar06's Avatar
OK I unplugged the battery for over an hour, as soon as the key hit the "On" position the engine performance reduced light came on, it threw the following codes,
p0068
p0102
p0223
p0340
p0341
p1516
I'm stumped, I don't know what else to look at, Im replacing the camshaft position sensor, crankshaft position sensor, and I'm going to see if I have an extra throttle body laying around to replace that too. Any more ideas?
Old Apr 6, 2013 | 08:35 PM
574's Avatar
574
Welcome to car modding... Sounds like a bad CPS to me. I'm not looking up all those codes but from what happened it kinda sounds like it went bad. Fairly common
Old Apr 6, 2013 | 08:43 PM
Mendomar06's Avatar
What I don't understand is why its throwing codes for the throttle body and intake cam, are they some how dependent on each other? Eg if cam sensor goes bad it will throw throttle code vice versa?
Old Apr 6, 2013 | 10:49 PM
rivaladore's Avatar
One sensor being bad can cause a plethora of codes thrown. A lot of things going on inside the pcm and it uses data from mulitple sensors at one time. If some calculaiton or comparison is being done and one sensor is bad it will look like multiple rhinga arbad. Code can only be so smart
Old Apr 6, 2013 | 11:43 PM
Mendomar06's Avatar
Yea you're right, I got the Cam position sensor, crank sensor is ordered and I'm borrowing a throttle body from my friend so let's hope something fixes it
Old Apr 6, 2013 | 11:56 PM
rivaladore's Avatar
Good luck and keep us posted, my gut feeling says throttle body
Old Apr 7, 2013 | 12:03 AM
rivaladore's Avatar
Don't feel bad if it takes a few tries, so called certified mechanics get stumped when it comes to simple things like lnf cracked intercoolers.
Old Apr 7, 2013 | 12:48 AM
mike1coolguy88's Avatar
Sounds to me like its a wirring issue to throw all those codes, possibly a bad ground that feeds the grounds for all those sensors or u lost the 5v reference to those sensors I would look for a chaffed or broken wire I doubt replacing sensors will fix this issue
Old Apr 7, 2013 | 02:09 PM
Mendomar06's Avatar
Ok I'll look over all the connections, I didn't see any wires that looked bad but I'll look it over again.
Old Apr 8, 2013 | 07:23 PM
Mendomar06's Avatar
Looked over connections and nothing out if the ordinary, replaced camshaft position sensor and still nothing keeps throwing codes and won't start
Old Apr 9, 2013 | 08:08 PM
Mendomar06's Avatar
Old Apr 9, 2013 | 09:15 PM
rivaladore's Avatar
I would definitely try swapping out throttle bodies with someone local. Or you can try pming mogorat427 he always has an insane amount of cobalt parts for sale. Probably has a few lsj throttle bodies
Old Apr 9, 2013 | 10:24 PM
Mendomar06's Avatar
I already swapped the throttle body with one that I'm positive works, I also replaced the cam sensor, tomorrow I'm replacing the crank one, any other ideas, thoughts?
Old Apr 9, 2013 | 10:29 PM
JapEatr's Avatar
South Central *********
Put cyl 1 in tdc, pull cps housing an realign hex
Old Apr 9, 2013 | 10:32 PM
Mendomar06's Avatar
Ok I'll try that bro, thanks
Old Apr 10, 2013 | 07:15 AM
rivaladore's Avatar
This.......forgot to mention when replacing that sensor
Old Apr 10, 2013 | 11:37 AM
Mendomar06's Avatar
Damn ok well I replaced the sensor but only moved that cap back far enough to where the sensor would clear that hose, I'll take a look at it, I was kind of scared to take that cap off all the way
Old Apr 10, 2013 | 10:18 PM
Mendomar06's Avatar
I swapped the throttle body out again with another one and now none of them work, before I could hear/watch it moving now nothing with any of them! I'm so frustrated I don't know what to look for anymore
Old Apr 10, 2013 | 10:38 PM
rivaladore's Avatar
What do you mean watch it moving? Are you trying to start your car with the intake piping disconnected? You checked all fuses and gone over the wiring harness? even all the way down to the maf sensor behind the headlight? Sure you installed that cps sensor right I know many people have installed them wrong. Did you ever physically move the throttle body plate? Bc that can **** it up.
