Help!! Battery box q.....
Old Apr 29, 2011 | 09:46 PM
cobaltsssc760's Avatar
So i have an optima yellow top in my car now and thats not keeping up with the system i have so im gonna buy a kinetik hc1800 i was wondering if anyone knows if this will fit? The hc 1800 dimensiona are 10"x6.81"x6.5"...
Old Apr 29, 2011 | 09:54 PM
BLAZIN07SS's Avatar
I'm too JDM for you
stock battery is a group 90 with the following dimensions:
L = 9 11/16
W = 6 7/8
H = 6 7/8
the kinetic hc1800 should fit fine
Old Apr 30, 2011 | 01:15 AM
Dimensions: 10"x6.5"x8.2" thoes are the kinetik hc1800
Old Apr 30, 2011 | 04:48 PM
bump anyone know if it fits?
Old Apr 30, 2011 | 07:30 PM
stonny9's Avatar
I would trust Blazzin. Plus it is simple dimension comparison. He works for his family's battery distribution company and installs high end batteries almost everyday.
simple to do go out to ur car and measure the battery compartment. Only thing I would worry about is the height. You spent 3x as much time/energy waiting for someone to post their opinion when you could of just walked out to your car and measured yourself.
Also if your battery is going dead/low then it is safe to say that you need a bigger alternator or a two battery setup.
Old Apr 30, 2011 | 09:45 PM
BLAZIN07SS's Avatar
I'm too JDM for you
ok. you posted different measurements in your first post so i didn't bother to look them up. the only thing i would be worried about is the height pushing up on the rear carpet.
Old Apr 30, 2011 | 09:52 PM
denlou's Avatar
Other than the tie down, I don't imagine size is an issue anyway, there's a lot of room in the trunk
Old Apr 30, 2011 | 11:55 PM
YelloEye's Avatar
This or a twin alternator setup.
Old May 1, 2011 | 12:12 AM
1fastSSBalt's Avatar
How many watts is your system? I was pushing 1600 watts with some old audiobahn alum q 12's 2 farad capacitor(had dual amps) after market head unit when I had my 97 taurus swapped to an Optima yellow top and never had an issue and I believe I ran that battery for around 4-5 years minimum.
Old May 1, 2011 | 03:18 AM
my car sat for a summer in palm sprigs... lets just say im stoked i jumped it back to life and its been running this long 120deg will cook a battery to ****. and im gonna run a two batt setup i was just asking because i was debating on buying the battery box made for the battery or fit it in stock spot. im gonna run a hc 800 right next to the 1800.
Old May 1, 2011 | 10:11 PM
stonny9's Avatar
Our batteries should last a little longer as they are away from the heat of an engine bay. I am still on my stock battery from 2005 and 70k miles with no signs of dieing.
Sl0wbaltSS
Nov 21, 2018 11:11 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
dennis69
Oct 20, 2015 04:49 PM
grampss
Sep 27, 2015 08:51 PM
c_m_shooter
Sep 27, 2015 04:40 PM
