Help! Broke a bolt & Can't find
I am need of some help locating a bolt for my engine. I snapped the banjo bolt that holds on the steam outlet to the coolant resivoir. The line sits above the fuel line and runs to right above the big radiator hose that goes over the S/C. But I can't find the bolt anywhere. went to the dealership and nothing. ANY HELP would be much appreciated
check www.GMpartsdirect.com
go to their catalog and look for it, they have everything and even break it down so u know what part ur ordering down to the plastic push tabs that hold things down
can't buy it from gm without buying the whole metal line to the resevoir.and its around $70. ask me how i know how
I bought a 10x1.5 banjo bolt and a tap and just taped it out.. its worked fine since last winter when i broke the same bolt
Tapped the threads to a different size.. the normal thread is a 10x1.25. i could not find that banjo bolt anywhere.. a local store had a 10x1.5 banjo bolt in stock, so i bought a Tap (a tool) and tapped the hole for a 10x1.5 bolt
thanks man I am going to go and give it a try I will let you know how it goes.
agentirons
Oct 16, 2015 02:11 AM
