help with a conversion (injectors)
Old May 4, 2006 | 11:50 AM
1fstss's Avatar
i have a set of 650CC/min injectors sitting in my closet, converted what lb/hour are they? i ran this neat little converter but the only option was lb H2O/ hour and it came out to like 85, that cant be right!! someone here has to be smart enough to figure this out!!
Old May 4, 2006 | 12:00 PM
automobiliben's Avatar
All you need is the density of the fuel and you should be able to figure it out.
Old May 4, 2006 | 12:02 PM
Tomtwtwtw's Avatar
If I'm doing my math right, 650cc/min is roughly equal to 39 liters/hr, which is about 10.3 gallons/hr, and at approx 6.8 lb/gallon of gas, you've got about 69 lb/hr of fuel.
I did some rounding, so that's probably +/- a couple pounds.
Old May 4, 2006 | 12:19 PM
WopOnTour's Avatar
1lb/hr = 10.5 cc/min
650/10.5
I get 61.9 lb/hr
Old May 4, 2006 | 12:31 PM
Tomtwtwtw's Avatar
Haha...I fat-fingered my results. Gas is 5.8 lb/gallon, not 6.8. (this of course varies with temp) It should be closer to 60, or right in the neighborhood Wop got as well. Either way you look at it, they're much higher flowing than even our stage 2 upgrade.
Old May 4, 2006 | 12:40 PM
HiSpdPursuit's Avatar
wow those are huge injectors...hope you dont put those on your car or you will be shooting major flames out of your tailpipe...
DarrenGC
Dec 24, 2021 01:55 PM
Sl0wbaltSS
Nov 21, 2018 11:11 PM
patooyee
Oct 15, 2015 05:11 PM
yellow dragon
Sep 28, 2015 09:49 PM
