Help, Coolant leaking
Old Aug 10, 2008 | 05:32 PM
Wolf117's Avatar
This morning i put on my hahn header, downpipe and cat back. i started the car and let it idle and there was coolant leaking. i turned off the car and looked and right underneath the header there is a bar that has a saab sticker that is leaking coolant on the side. the header is barely barely touching this pipe and isnt applying any pressure. what do i do to stop it from leaking?
Old Aug 10, 2008 | 05:39 PM
BlackSSNick's Avatar
this exact same problem happened to me. I had the same header you did and my pipe leaked, I sent mine back to hahn. There is nothing you can do about it except move that pipe down so the header clears it. Its a water pump pipe not a coolant pipe so im told. If you call hahn they will tell you to loosen the coolant pipe and rotate it downwards so it clears the header.
Old Aug 10, 2008 | 05:42 PM
ls1fbody's Avatar
Haz l33t wheelz.
the water pump pumps the coolant, so actually it's both. just fyi. not criticizing, just so people don't get confused.
to the OP, hows the hahn sound?
Old Aug 10, 2008 | 05:44 PM
i have the Hahn 3" dp and Hahn 3" cat-back, and it sounds great, I'm happy with it. Best sounding cobalt exhaust IMO. I've heard alot of others and I cringe when I hear other exhausts.
Old Aug 10, 2008 | 05:46 PM
ls1fbody's Avatar
Haz l33t wheelz.
yeah, that's what's keeping me from an exhaust, is the sound of a 4 banger, it's never very good, regardless of the quality.
Old Aug 10, 2008 | 05:47 PM
well to be honest with you, your not gonna get away from the 4-banger sound, thats a given. But if you want a deep sounding exhaust, you can't go wrong with the Hahn 3" Cat-back. If I have time this week I'll do some drive-bys when I get my car back from the dealor, Watch for my thread. Hahn Exhaust Drive-by's i'll call it, or something liek that.
Just don;t buy their header, I put the stock header back on, I'm gonna get the extrude-honed header from GM soon.
Old Aug 10, 2008 | 05:48 PM
Altiery54's Avatar
ls1 i have hahn header, hahn custom catless downpipe, and hahn cat-back and it sounds like sex man!!!! its a wee-bit loud around 4500rpms but its not a ricey sound more like a 4cyl. thats got some power behind it. its kinda hard to explain
Old Aug 10, 2008 | 06:04 PM
Wolf117's Avatar
So it will stop leaking if i do that?
i dont know. it ran for like 30 seconds haha and then i just hear my friend yelling turn it off!
Old Aug 10, 2008 | 06:12 PM
ls1fbody's Avatar
Haz l33t wheelz.
haha it's all good.
Old Aug 10, 2008 | 06:19 PM
it should stop leaking
Old Aug 10, 2008 | 06:27 PM
Wolf117's Avatar
ok, and when i unbolt it all my coolants gonna leak out isnt it?
Old Aug 10, 2008 | 06:30 PM
as far as I know you loosen it just enough to turn it, yes coolant will leak out, thats a given, don't take it off completely.
Old Aug 10, 2008 | 06:38 PM
Wolf117's Avatar
what bolts losen it? theres a lot, and theres some behind the header. i dont want to take the header all the way off again lol.
biniecki
Oct 25, 2015 02:23 PM
brandon04
Oct 21, 2015 07:04 AM
tomj77
Oct 4, 2015 11:39 AM
grampss
Sep 27, 2015 08:51 PM
riceburner
Sep 26, 2015 12:57 AM
