Help with different types of heat exchanger!
Old Jan 7, 2011 | 11:20 PM
ss slobalt's Avatar
im looking to get a h/e pretty soon and whats one that everyone seems to love? and also what is the main difference with the s1 s2 and s3 from zzp? and do you need a specific amount of mods or power to have an s3 or something. please help!!
Old Jan 7, 2011 | 11:41 PM
CanadianCobalt's Avatar
More cooling the better, putting a HE on a stock car wouldn't hurt it at all. Stage 3 is lighter and more efficient than the other stages along with holding more fluid. If your not on a budget OTTP Griffin HE is supposed to the the shiz.
Joel
Last edited by CanadianCobalt; Jan 7, 2011 at 11:55 PM. Reason: I murdered my spelling.
Old Jan 7, 2011 | 11:54 PM
07BoostedG5's Avatar
my secondary was simple and cheap but works well for me, Cobra HE, but I do have dual pass and opt B,
My m62 is pretty cold after a long trip you can rest your hand right on it.
Old Jan 7, 2011 | 11:56 PM
G11's Avatar
G11
i got the griffin h/e with dual pass and opt b and also going to be running methanol thru it to make sure the charger is cool and not burning up
Old Jan 8, 2011 | 10:49 AM
ss slobalt's Avatar
so the zzp s3 is the best one under the griffin? and i only have a catless dp and CAI on now but i will have headers, new muffler and maybe some small stuff for the engine so would it matter what size stage i get or can i just go get the s3 and throw it on?
Old Jan 8, 2011 | 01:49 PM
Yea, I'd say it is. Mine works great. You can throw any cooling you want on, like I said the more the better.
Are you going to pulley down at all?
Joel
Old Jan 8, 2011 | 02:11 PM
Josh@ottp's Avatar
Our stage 1 unit uses the same style core as their stage 3, just our stage 1 is slightly bigger and alot cheaper. Everyone seems to like our unit so I would ask around about our gen 4 heat exchanger
Old Jan 8, 2011 | 02:12 PM
Rodimus_Prime's Avatar
get the griffen that ottp sells, anything else your better off staying stock
Old Jan 8, 2011 | 10:18 PM
06SS ALL DAY's Avatar
this is a question... zzp all the way if you know whats good for you
Old Jan 8, 2011 | 10:47 PM
Stone629's Avatar
I went with the ZZP stage one HE. I highly recommend a bigger one. My M62 is almost to hot to touch after a couple pulls, or a drive around town. Get the S3 and be done with it.
Old Jan 8, 2011 | 11:07 PM
Either get the Stage 3 or Griffen, go big and do it once as the guy above said.
How very ignorant and uninformitave. Thank you.
Joel
Old Jan 9, 2011 | 03:45 AM
ss slobalt's Avatar
ok sweet and im going with the s3. its only 200 somethin bucks and its worth it. if its close to the griffin id rather save myself 300 bucks. and yes joel im going to pulley everything once all my cooling mods are put in.
Old Jan 9, 2011 | 09:03 AM
87gn06gto07irl's Avatar
I switched from a S3 to the Griff and see almost a ten degree improvement.
Old Jan 9, 2011 | 10:22 AM
Josh@ottp's Avatar
Its not close to the griffin at all.
Old Jan 9, 2011 | 02:15 PM
Traviper's Avatar
i personally have the ZZP S3 heat exchanger, thats my olny cooling mod on my 2.8
i can make a couple runs and immediately touch the SC and not burn my hand. i plan on getting option B in good time though.
and no offense to OTTP or anything, but shipping will be faster with ZZP.
Old Jan 9, 2011 | 02:36 PM
I had contrary experiences, ZZP wanted pictures of my drivers license before they would ship to me. 6, 1. Half dozen the other.
Joel
Old Jan 9, 2011 | 04:52 PM
Josh@ottp's Avatar
What heat exchanger you have has no effect on how hot or cold your supercharger will be.
Also we have both heat exchangers in stock and they will ship the same day if you order by noon.
Old Jan 9, 2011 | 06:10 PM
ULWizSS's Avatar
Both ZZP and OTTP make quality H/E. I am also running a ZZP S3 H/E with a 2.8 with more cooling mods planned before track season.
Best of luck in what you choose.
Old Jan 9, 2011 | 09:02 PM
Traviper's Avatar
i had a feeling that the bigger the heat exchanger, the cooler the temps, but i guess that would be a cooler intake manifold though.
on a side note i did by my stage 2 kit from OTTP
Old Jan 9, 2011 | 09:54 PM
Leafydialupking's Avatar
100% correct. The heat exchanger (well actually the whole air-water intercooler system) cools the air after the blower, not before it.
Old Jan 10, 2011 | 11:52 AM
ss slobalt's Avatar
if the zzp s3 cools around the same as the griffin with only a ten degree difference its gonna be worth saving the 300 dollars and then just throw the dual pass in and all. thanks for the help tho guys!!!
Old Jan 10, 2011 | 04:21 PM
the zzp does not cool the same as the griffen
and 10 degrees is the difference between losing several degrees of timing, timing is worth 1-3hp per degree
but if you dont want to pay then your not going to have as much fun playing
Old Jan 10, 2011 | 07:36 PM
G11's Avatar
G11
^^^and that my friends is why i spent the extra
Old Jan 11, 2011 | 08:54 AM
If you understand what a h/e does, that's all the reason you need to spend the extra!
DarrenGC
Dec 24, 2021 01:55 PM
jimbofug007
Oct 2, 2015 12:06 PM
n20saturn
Sep 30, 2015 12:26 AM
jmelton327
Sep 26, 2015 10:04 PM
OrangeCoba
Sep 25, 2015 06:06 PM
