help gear/trans prob
Old Apr 22, 2013 | 09:40 PM
buter's Avatar
Exclamation help gear/trans prob
I just replaced my throw out bearing and clutch master cylinder. I can't get the car into gear when the car is running and if i go to start it with my foot on the cluch and in gear the car wants to move. I've bleed everything time and time again and now I'm out of ideas! Can any one help me?
Old Apr 22, 2013 | 09:45 PM
09BlueBaltSS's Avatar
Faulty tob or still air in the system
Old Apr 22, 2013 | 09:49 PM
EXsoccer1921's Avatar
Try bleeding more. Im about to diagnose the same thing in my car
Old Apr 22, 2013 | 10:29 PM
buter's Avatar
so you guys don't think it would have anything to do with clutch?
Old Apr 22, 2013 | 11:40 PM
it's either the tob or the pressure plate.
Old Apr 23, 2013 | 11:06 AM
SaberD's Avatar
make sure the clutch fluid distribution block on the top of the trans is secured properly. It's very easy to put the clip on without it being fully seated in the transmission case. Also, did you replace the clutch fluid pipe?
Old Apr 24, 2013 | 11:01 AM
buter's Avatar
Still no luck, I just bleed another pint of brake fluid through it. I didn't replace any of the lines. I did notice that there was a very small amount of play where the line goes into the block. idk i might order a new clutch and pressure plate and tear it all back apart.
Old Apr 24, 2013 | 11:32 AM
Sully20's Avatar
This^.....It sounds like a faulty TOB, Trust me I had one in my car lol.
Old Apr 24, 2013 | 09:47 PM
buter's Avatar
its a brand new throw out bearing. I ordered an phoenix stage 3 clutch, i should have it friday morning and it come with a new throw out bearing. if this doesnt fix it i dont know else it could be.
Old Apr 25, 2013 | 02:41 PM
Gelladuga69's Avatar
Brand new could still be faulty. There was a big thing about this awhile back with LNF throwouts.
Old May 25, 2013 | 01:54 PM
buter's Avatar
hey guys quick update. The hub in the old clutch pretty much exploded. When I took the old one out, one of the springs just fell on the floor!
Cobalt08LS
Jun 19, 2016 07:29 PM
dieGone
Sep 23, 2015 10:20 AM
artawesome
Nov 3, 2006 07:31 PM
artawesome
Aug 10, 2006 07:08 PM
