help gear/trans prob
I just replaced my throw out bearing and clutch master cylinder. I can't get the car into gear when the car is running and if i go to start it with my foot on the cluch and in gear the car wants to move. I've bleed everything time and time again and now I'm out of ideas! Can any one help me?
make sure the clutch fluid distribution block on the top of the trans is secured properly. It's very easy to put the clip on without it being fully seated in the transmission case. Also, did you replace the clutch fluid pipe?
Still no luck, I just bleed another pint of brake fluid through it. I didn't replace any of the lines. I did notice that there was a very small amount of play where the line goes into the block. idk i might order a new clutch and pressure plate and tear it all back apart.
its a brand new throw out bearing. I ordered an phoenix stage 3 clutch, i should have it friday morning and it come with a new throw out bearing. if this doesnt fix it i dont know else it could be.
