Help with HPT
Old Nov 8, 2009 | 04:10 AM
revolution607@yahoo.'s Avatar
Help with HPT
so about a month ago, me and 3 other cobalts got tuned. one of the cobalt guys being rage915, you might of seen his thread about him getting a bad tune. anyways, my car has been throwing misfire codes, i have had 4 already in the past 2 or 3 weeks. well today i went over to rage915's house to get my tune pulled from my car to see if maybe i got a bad tune as well. ive also taken into consideration that misfires can be caused my plugs, coils etc. but i dont believe its any of that. i figure if one person got a bad tune then im sure the tuner didnt do so well with my car either. so as we are trying to get my tune pulled from my car, it goes through the first 2 steps but then stops and fails on step 3 which would be some security step. i guess to validate the vcm or something along those lines. so we try a couple dozen times and it still doesnt work. we keep getting the same fail error so i ask some of my friends, what can cause that? and they all tell me the same thing which is to make sure my key in on the "on" position and to make sure only the editor part of hpt is open. we then check to see if everything is connected properly and that everything is right and try again. still nothing... then we try it on rage915's balt and it works. i guess i can assume it has something to do with my car.
so my question to you guys, who have dealt with hpt, is why isn't letting me pull my tune from my car?
Old Nov 8, 2009 | 04:30 AM
mkulrey13's Avatar
check fuse for OBD port?
Old Nov 8, 2009 | 04:33 AM
yea i tried that but couldnt find which fuse it was...
is it the ecm one?!
Old Nov 8, 2009 | 04:35 AM
mkulrey13's Avatar
Last i thought it was the cigar lighter fuse.
Old Nov 8, 2009 | 04:41 AM
yea thats what i was looking for but i couldnt find anything that said or somewhat looked like cigar lighter lol
do you know what abbreviation they use for the cigarette lighter?
Old Nov 8, 2009 | 04:46 AM
jimbos'ss's Avatar
its prolly the vats system, reset the security system before trying to write or read the vcm
basically open the door, close it, lock till the alarm beeps, unlock, open the door close it. then try to read or write to the vcm
Old Nov 8, 2009 | 04:52 AM
i dont have one of those key fob things. it broke so i just have a key lol
would i still do all of what you said minus the "lock till alarm beeps" part?
Old Nov 8, 2009 | 04:54 AM
jimbos'ss's Avatar
thats a good question, i have never done it without the key fob.
Old Nov 8, 2009 | 09:36 AM
WickedSS2005's Avatar
Your car is fine!!
Rage is using the beta version of HPT (version 2.23, which I sent him for the LNF tuning) which sometimes will not work with the LSJ motors. He will need to take the program off and reinstall version 2.22 of HPT. That will allow you to pull the tune off the car.
I can email him the HPT 2.22 install file as well so that he can pull your tune
Old Nov 8, 2009 | 09:43 AM
Rage915's Avatar
Wicked can you send me the 2.2, so once we are done , i can pull revolutions tune.
Old Nov 8, 2009 | 10:26 AM
OntarioKev's Avatar
Also when changing in between years on cobalts, sometimes you have to delete the VCM Suite.cfg file in the settings folder. You will need to re-enter your application key after that, but then it will pick it up.
Kevin
Old Nov 8, 2009 | 10:33 AM
That is true, but no the fix needed in this case
Old Nov 8, 2009 | 12:53 PM
awesome, thanks Wicked and everyone else for your help.
Old Nov 8, 2009 | 08:31 PM
turboecotec02's Avatar
I just had this problem. Do as followed- delete the file in your hp tuners setting folder VCM Suite. This is how you do it. Right click start , click explore. click c:/, then documents and settings then click w/e user you are in windows with, then click documents- hp tuners -settings- then delete the file VCM Suite. Once you delete that file when you load hp tuners, it will ask you for your app. key agian. Thats it. Then it will work.
Old Nov 9, 2009 | 12:14 AM
Again, this is not the same issue.... He's having compatibility issues with version 2.23 beta of HPT and his LSJ. Known issue, all resolved
Old Nov 11, 2009 | 11:13 PM
So I switched over to the 2.22 and it's still not letting me read my tune... Anyone have any idea what it could be?
Old Nov 12, 2009 | 12:30 PM
jimbos'ss's Avatar
did you try the vats thing yet? it can also be disabled with the scanner too
Old Nov 12, 2009 | 06:23 PM
whats that?
Old Nov 12, 2009 | 06:52 PM
ChevyRockstar's Avatar
Bump for help, I cant log revolutions car, i get a error to check connections and make sure the key is on.
I'm using 2.22
Old Nov 13, 2009 | 03:39 AM
Rage915's Avatar
try that whole vat thing, and also look for that damn fuse for the lighter...
Old Nov 15, 2009 | 04:20 PM
Bluelightning
Aug 31, 2015 12:17 PM
soaxin
Tuning
Aug 28, 2015 12:06 AM
3fo893013L
Tuning
Feb 2, 2007 11:54 PM
nduchene
North East
12
Aug 16, 2006 10:35 AM
charged_sunfire
May 28, 2006 02:30 PM
