Help I’m loosing boost
Old Nov 2, 2007 | 04:07 AM
Slowbalt SS05's Avatar
I’m going crazy here can any one help my I was getting off work today, I put it in first here and I have no boost it only goes to 5psi and then it dies down I’m goings nuts. All the other gears I get full boost. HELP PLEASE I’m goings crazy here. I checked the GM warranty and this is what I got 36 basic warranty and 100 powertrain warranty. I have 37thousand mile in my 05 do you think wants going on to my car falls under powertrain warranty and I prey that the dealer warranty it. Help any one.
Check the warranty list
http://www.chevrolet.com/warranty/
Help
Last edited by Slowbalt SS05; Nov 2, 2007 at 04:07 AM. Reason: Automerged Doublepost
Old Nov 2, 2007 | 04:14 AM
2.0freakotec's Avatar
well if ur getting 5 pounds of boost in 1st grear thats great i dont think our cars boost more than 7 psi in 1st and about the warranty part u know gm will fight with u not to warranty it hope they will and best of luck to ya
Old Nov 2, 2007 | 04:26 AM
justin04's Avatar
i thought it was 36k bumper to bumper and 100k on power train
Old Nov 2, 2007 | 04:27 AM
i been getting before when i floor it 11psi i dont think its normal for it to be 5psi
Old Nov 2, 2007 | 04:28 AM
Super_SS's Avatar
A.bad boost gauge
B.Boost solonid might be bad
C.Leak Somewhere?
Old Nov 2, 2007 | 04:31 AM
Yeah your right but whats happening to my car should fall under the powertrain right?
Originally Posted by Super_SS
A.bad boost gauge
C.Leak Somewhere?
I think it may be the leak but I check under the hood and I don’t hear any air leak the problem is just in first gear.and how can my bust solonid go bad?
Last edited by Slowbalt SS05; Nov 2, 2007 at 04:36 AM. Reason: Automerged Doublepost
Old Nov 2, 2007 | 04:51 AM
Super_SS's Avatar
take some break cleaner and spray it along some lines...wont do any damage to motor,will just bubble if there's a leak
Old Nov 2, 2007 | 05:08 AM
jeffrieckonfiyaaa's Avatar
you know, i had the same damn problem when i got my car, and it had less than 3k miles on it, i took it in, and they told me it was "normal" for it to peak at 3-5 psi in first, however i thought i saw it at 10 psi.
Old Nov 2, 2007 | 05:15 AM
i know i am not seing things but i always checked my psi when i would drive my car and every time it would boost more than 5psi, and i can feel the decrease and power when it starts diying down at 5psi, i don't think this is normal because it is very obvious that i feel less power in first gear then when i first got it. Does your car now still boost 3-5 psi?
Old Nov 2, 2007 | 12:47 PM
yeah, still boosting 3-5 psi. i have taken my car in like 4 times already, and the every time i complain of the pull being weak, but they still insist that its nothing.
but then again, they can't seem to explain why my window motors keep blowing on me.
Old Nov 2, 2007 | 01:09 PM
Deathscythe's Avatar
I rarely see my boost even cross over into the boost range in first gear but the tires break free with just a little throttle input. I don't think the boost was really meant to set in until second gear anyway.
Old Nov 2, 2007 | 01:14 PM
D4u2s0t's Avatar
i wish my car would only boost 5psi in first
Old Nov 2, 2007 | 07:43 PM
postal_ss's Avatar
cluch?... you may need a new one
Old Nov 2, 2007 | 08:10 PM
I have a new clutch stage 3 Clutch Masters, every other gear I’m boosting 11psi. It’s that first gear that’s getting me.
Old Nov 2, 2007 | 08:20 PM
shaunmcdee's Avatar
My car would only see 5 psi on my boost gauge as wll in first gear, But then again my first gear ends a hell of alot faster than yours... are you spinning the tires thru first? that would make up for it. As for limiting boost in first gear, no, the cars ecm gives you 100% boost off the line.
IMO its seems like its normal. Your holding boost thru the rest of the gears.
Dude i live in riverside, hit me up pm me, and ill give you my number, i have hptuners we can log this thing, lol
Old Nov 2, 2007 | 11:22 PM
pm sent
So it can just be my mined playing tricks on me.
Last edited by Slowbalt SS05; Nov 2, 2007 at 11:22 PM. Reason: Automerged Doublepost
Old Nov 3, 2007 | 04:31 AM
Maxim_X's Avatar
Maybe your boost solenoid came loose, adjust it correctly. Push it all the way down and tighten it that will probably fix the problem.
Old Nov 3, 2007 | 04:55 AM
Talking
where is the boost solenoid located
Old Nov 3, 2007 | 05:47 AM
Dayta's Avatar
isnt 1st more gears less boost?
turbochargedss2012
Sep 20, 2023 12:17 PM
Solaris99
28
Mar 15, 2017 01:22 PM
Jan 12, 2016 12:01 AM
Tupp
Sep 30, 2015 08:18 PM
jmelton327
Sep 26, 2015 10:04 PM
