Help!!!!!!! I Need Aftermarket Sleeves!
Old Feb 15, 2009 | 10:56 PM
Armyguy151's Avatar
Just as it say's I need some aftermarket sleeves. My number 4 piston ring broke and i'm doing a full build right now. I'm looking to get 550-600Whp out of the build. I'm putting a Forced Performance 3065R turbo..So any help would be great...Thanks
Old Feb 15, 2009 | 11:00 PM
06cobaltindallas's Avatar
darton has sleeves that u can get
Old Feb 15, 2009 | 11:04 PM
Armyguy151's Avatar
I called them and they didn't have anything for the 2.0 only for 2.2
Old Feb 15, 2009 | 11:06 PM
SC07's Avatar
they might have given you some mis-information there.
im fairly sure the darton sleeves WILL work, I looked into it.
someone correct me if im wrong.
Old Feb 15, 2009 | 11:21 PM
Armyguy151's Avatar
I called them and asked them if they had any sleeves for a 2.0 cobalt ss, and he said no just for the 2.2!!! I even asked him if there was any way that i can make the 2.2 fit and was told no. I will call them again tomorrow or tuesday and ask again.
Old Feb 16, 2009 | 08:06 AM
Maxim_X's Avatar
The car have the same bore. I figure something like that should work.
Old Feb 16, 2009 | 10:23 AM
Armyguy151's Avatar
see thats what i thought, hell i figured there was a way for it to fit but they said no.
Old Feb 17, 2009 | 09:49 PM
Armyguy151's Avatar
Well I called Darton today and they DO NOT have any sleeves for the 2.0....They are making some and should have them out in 2-3 months!!!
Old Feb 17, 2009 | 10:07 PM
Code-Red's Avatar
MID series?
I'm a bit new, but is the water jacket surrounding the sleeves open? If so, has anyone developed a block guard yet?
Old Feb 17, 2009 | 10:10 PM
Armyguy151's Avatar
MID? i dunno about the water jacket....I know it's not pretty when a ring breaks and messes up your piston and sleeve
Old Feb 17, 2009 | 11:18 PM
sleeperbalt's Avatar
They make them for the ecotec. All the block are going to be the same! I just had my block done 3 weeks ago.
They start at 86mm and go up to 90mm bore.
I go mine on ebay from titanmotorsports for 624 shipped!
Old Feb 18, 2009 | 06:43 PM
SC07's Avatar
sleeperbalt, you have the hahn kit correct?
did you just get the 2.2 sleeves, and they work in your block, what is your LSJ bored and stroked too?
you do have an LSJ right?
Old Feb 18, 2009 | 07:13 PM
Code-Red's Avatar
I'm interested what setup you used too. Possibly a 2.4L crank with a shorter custom rod/piston setup?
Old Feb 18, 2009 | 07:25 PM
car_guy_09's Avatar
Sub'd
Old Feb 19, 2009 | 06:13 AM
Armyguy151's Avatar
sleeper, i sent them a email and they called darton also and they said they did not make sleeves for the 2.0 yet. so what sleeves did you use..bored...ect????
Old Mar 11, 2009 | 01:51 PM
UgliestTurtle's Avatar
pics please
Old Mar 11, 2009 | 06:09 PM
StevesBlack06's Avatar
my 2.0 is in the machine shop as we speak for this work. they are the same bore i dont see any reason why they would be different. my machinist didnt say anything about them not working. he has done both mine and my buddies work in the past. my buddies 2.2 is already done. looks amazing.
Old Mar 11, 2009 | 06:16 PM
HunterKiller89's Avatar
just buy the ones they claim are only for the 2.2. Its the exact same bore in the same block design, so its a direct fit regardless of what they believe
Old Mar 11, 2009 | 06:36 PM
EXsoccer1921's Avatar
bore is the same, yes. stroke is not the same. if you do get the l61 replacement sleeves they will need to be machined down. which i would just resurface the whole deck.
also. i'm not sure if the o.d. of the sleeve is different. i don't believe it is but it will be another thing for you to look in to
Old Mar 12, 2009 | 02:20 PM
06noscobaltss's Avatar
I have been working with Darton for the past few months with sleeves for my motor. I have to send them a junk block so they can make sure the casting works without any issues before they will do the sleeves on my good block. Yes that 2-3 months is correct because that is the time table they gave me to be done with testing and producing these sleeves. Only prob is... No money for me to spend with Darton...
Old Mar 12, 2009 | 05:28 PM
this is all news to me seeing as how my block is getting this work done right now... my machinast hasnt said a word to me about their being any problems
Old Mar 12, 2009 | 05:59 PM
red06SC's Avatar
I was under the impression that the crank was all that changed the stroke in these cars.
Old Mar 12, 2009 | 09:27 PM
that is correct but its the clearance between the crank and the bottom of the sleeves that MAY be the problem. i guess the only way to know is for someone who has already had em done to come forward or wait for my work to be finised.
Old Mar 12, 2009 | 09:33 PM
TurboTechRacing's Avatar
Sleeves should fit, as posted above, modification may be needed (slightly) If you have a machine shop put them in, it will be NO problem for them to make them work.
BTW we carry them at www.TurboTechRacing.com
chefhhr
Oct 26, 2015 10:36 PM
metroplex
Sep 27, 2015 07:48 AM
Extreme Dimensions
Sep 24, 2015 07:51 PM
Extreme Dimensions
Sep 24, 2015 05:24 PM
budah93
Sep 15, 2015 07:23 AM
