help with internals build
Old Nov 28, 2006 | 11:27 PM
CbYellowSS's Avatar
alright if this is old news or anything sorry
but heres what i have so far
diamond pistons from intense
jbp cams
jbp cam gears
jbp stage 2 head kit
first will the diamond pistons work with the jbp
and second what else do i need done to the engine internals
for those who dont know whats in the stage 2 head kit
Full Race Port and Polish
Glass Bead
Knife Edged Intake Runners
Port Matched Intake
Port Matched Exhaust
JBP LSJ High-Po Valve Springs
Viton Valve seals
JBP 3 Angle Valve Job
JBP Stainless Steel Valves
JBP Titanium Retainers
JBP Titanium Locks
Stock Guides
GM Head Gasket
Resurfaced Mating Surface
All Assembly Included
Est. Gains: 10-13%
all help is appreciated
Old Nov 28, 2006 | 11:36 PM
06noscobaltss's Avatar
ok i am doing almost the same build right now. first with the stage 2 head **** the STock valve guides! upgrade to their Bronze Valve guided! Cams are good, screw the cam gears you dont need them! intense racing costs too much for their pistons go directly through Diamond Racing. I saved over 200 by going directly through Diamond! Also get neutral Balance shafts if you are going for over 350 whp! and u can just get the rods if you want. I didnt want to have to tear down the motor again I wanted to do it all at once. You will need the cometic head gasket, Head Studs for sure! Everything I ordered is in my sig!
Old Nov 28, 2006 | 11:43 PM
CbYellowSS's Avatar
so first is taht it???
and where can i get the bolded???
i can get the balance shafts and valve guides from jbp also correct??
and from what i see you are saying
bronze valve guides
neutral balance shafts
cometic head gasket
and head studs
Old Nov 28, 2006 | 11:48 PM
1) read my sig to find out what else you need
2) valve guides are offered through JBP
3) Balance Shafts- CrateEngineDepot.com
4) Head Gasket, Head Studs, Rods- CobaltPerformanceParts.com
5) You will need New Piston Sleeves- Dealer can special order them!
bronze valve guides
cometic head gasket
and head studs
Old Nov 28, 2006 | 11:51 PM
CbYellowSS's Avatar
ok thanks for all the help
what kind of numbers do u think you will be putting down with just internals???
and does anyone else have any input??
Old Nov 28, 2006 | 11:55 PM
I honestly dont know. with everything I have a guy put down 425 with a 2.6 pulley... so I plan on being around there safely, plus add in the head and cams which he didnt have... hehe
Old Nov 29, 2006 | 01:05 AM
JBP's Avatar
JBP
If you have any further questions with your build, call us up and ask for Mev.
Old Nov 29, 2006 | 01:10 AM
sunfirejoe's Avatar
cam gears are more than neccesary they make or break tuning, they will get eveyrthing possible out of cams, you cannot take full potential of your cams w/out cam gears, so def put those on your list
Old Nov 29, 2006 | 08:35 AM
CbYellowSS's Avatar
so i have one vote for cam gears and one against...
any other input or votes???
y wouldnt i need them if i shouldnt
ineedacobaltss
Nov 7, 2015 02:25 PM
hacadacalopolis
Oct 28, 2015 06:09 PM
patooyee
Oct 15, 2015 05:11 PM
