Help me finalize my build plans
well price wasnt what i was thinking about although now that u mention it it could be lower... i want 6 rca outs all 8v, no internal amp, 2 HD slots (up to 150gb each), Dual layered DVD compatablity, DVD burning compatablity (along with dual layer) , 5.1 dvd audio compatablity
for all that id be more then happy to pay the current price
Now, about the dual layer DVD burner, can't help you there. But it should have no problem reading dual layer DVDs. Hell, if it did then it would have problems with a lot of the current movies out.
The problems are mostly with the hardware and not the software. I plan on running Flux Media's Centrafuse which is a program with far less problems then Streetdeck.
*edit*
You could also run Infillstation, which is Infill's native software for their systems.
*edit*
Doh, problems with software and not hardware. ARG!!! Most of the problems should be fixed in the next month or two (long before I get home) and I'm running a 3SIXTY which will get around the couple of problems they can't fix with software.
ya i have 2 three sixties on the way but i want 5.1 and the 360's just process the channels its givin but dont create surround sound.... i actually want to see it installed in your ride honestly
Stage 2 with intake, 2.9" pulley, and full exhaust is about my limit for power. Though I most likely will try to get it dyno, then road tuned to smooth everything out.
And Victory, I'm feeling I'm going to stick with the Pilot Sport PS2's. Make sure you get the PS2 model instead of the base Pilot Sport though. Big difference in performance.
LSX RWD S/C conversion
