Help me with mods please!!
Old May 14, 2012 | 12:59 AM
RogerSS0228's Avatar
I'm getting closer to tuning my car, mods will be 2.85inch pulley air box mod ngk bkr7e plugs catback exhaust and as for the injectors, will 60# be ideal for it? Please give me helpful answer I'm at 5000 ft elevation if that helps any
Old May 14, 2012 | 01:56 AM
Vander Nars's Avatar
60s will be enough u may even wanna go with a 2.8 but regardless of that running anything under a 3.0 u need a dual pass and front mount intercooler to keep that sucker cool, also u need headers and downpipe if u gonna be running that small of a pulley.
Old May 14, 2012 | 02:06 AM
turbosmart4's Avatar
i have a stage 3 kit for sale... includes zzp tuned pcm , 60s and harness, Front mount HE... 2.8 pulley and short belt
Old May 14, 2012 | 07:41 AM
Staged07SS's Avatar
Administrator
Administrator
heat exchanger....
Old May 14, 2012 | 07:43 AM
tylerjclance's Avatar
USA Y U NO HAVE AUTOBAHN?
methanol or E85(80#s for the corn)
Old May 14, 2012 | 09:40 AM
heat exchanger....
A intercooler is a type of heat exchanger, but im sure he knows to use the one designed for our car.
Old May 14, 2012 | 09:57 AM
Staged07SS's Avatar
Administrator
Administrator
Correct, but....
On our supercharged cars the "intercooler" is found within the intake manifold (4 laminova cores). The heat exhanger is found sandwiched between the radiator and a/c condensor. I'm merely correcting your terminology, because we don't need new members calling the heat exhanger an intercooler on the SS/SC.
Old May 14, 2012 | 11:58 AM
Correct, but....
ok ok but fmhe does not look near as cool as fmic
Old May 14, 2012 | 01:12 PM
what will i need the heat exchanger or dual pass for? im not going on the track or anything this is my everyday car and any time ill be racing is if someone thinks there car can beat me u know what i mean? haha
Old May 14, 2012 | 01:16 PM
maybe how much??
Old May 14, 2012 | 01:21 PM
Staged07SS's Avatar
Administrator
Administrator
The dual pass and or aftermarket heat exchanger will help your recovery time of your IAT2's (intake air temp 2). Keeping your IAT2's at bay will help you to avoid knock, and power loss.
Old May 14, 2012 | 11:23 PM
u will need both of them to keep from heat soaking ur car, its not about a track or multi pulls on a dyno, you can heat soak during daily driving easy if your running a 2.7 or 2.8 without support cooling mods, when u get beat by a stock ss sc u will understand why we tell u to get cooling mods.
Old May 14, 2012 | 11:26 PM
Chevycobaltss3's Avatar
Heat soak is the # 1 Killer of the power in any type of engine wether its NA or forced. More obvious in force inducted cars. Mainly due to the heat coming from the engine and parts likes the sc, turbo mani, turbo itself and etc. Its bst to have most cooling parts as possible. But you dont have to. ( but its recommended)
bigdeertz
Nov 17, 2016 09:41 AM
chefhhr
Oct 26, 2015 10:36 PM
Builttss
Oct 4, 2015 10:21 AM
nathan112i
Sep 30, 2015 07:12 PM
dieGone
Sep 23, 2015 10:20 AM
