help with piston selection
Old Oct 29, 2011 | 10:29 AM
Tjolley's Avatar
ok i just burnt the rings up in my 07 ss sc. im running a 2.5 pulley on my m62 with nos and many supporting mods. i burnt up the stock rings cuz i was to lazy to rip the engine apart and upgrade all that. so now im paying for it. lol so wat pistons and rings r good out there. thank u
Old Oct 29, 2011 | 10:43 AM
nwss's Avatar
just got the diamond forged pistons from ottp with all the awesome coatings and they are soo sexy and ottp shipped them out fast =D and they are priced to sell.
Old Oct 29, 2011 | 10:45 AM
nwss's Avatar
Old Oct 29, 2011 | 10:49 AM
Tjolley's Avatar
ok i was leaning that way so thank u for the info
Old Oct 29, 2011 | 10:56 AM
Tjolley's Avatar
well i hope its the rings i only have 40,000 miles on it and it blows the dip stick out and started smoking last night. if anyone has some info on that i haven't done any testing yet but that wat im thinking
Old Oct 29, 2011 | 11:09 AM
mrbelvedere's Avatar
you have more than likely took out a ringland on one of your pistons you need to pull the engine and get the block checked before you buy pistons
Old Oct 29, 2011 | 11:30 AM
Tjolley's Avatar
but the strange thing is that other than smoke the car seems to run fine. its smooth and everything
Old Oct 29, 2011 | 04:03 PM
well a dipstick popping out is the first sign of a busted ring land the reason you need to get the bores checked for taper and roundness is if they arent strait and round and the block needs bored (i wouldent go over .010) then the stock bore pistons you have wont work and that is money you have just pissed away because then youll have to buy an oversized set along with rings and not to mention if you dont check things out and assemble the engine more then likely you will just have an oil burner
on another note the bores need to be prepped properly by being honed with the ring manufacturer grit specs on the bores and they need to be clean and do not use synthetic oil in the engine for 500 to a 1000 miles
Old Oct 30, 2011 | 09:38 PM
Tjolley's Avatar
well i did a leak down test last night and all the cylinders tested fine but wen i pulled the surcharger and intake manifold i found a little tear in the gasket between a oil hole and a intake port. and a **** load of oil in the manifold and. i have the spacer that spacerthat should help with the heat sink. the gaskets that came with the spacer were different than stock. so i ordered a new gasket new plugs im gona port the surcharge and change its oil while im waiting for the gasket. ill let u all know how it goes. thanks for all help with my problem
hhrfreek
Jun 4, 2016 11:25 PM
ineedacobaltss
Nov 7, 2015 02:25 PM
HEATON
Oct 16, 2015 07:21 PM
Trav3480
Oct 1, 2015 08:17 PM
