HELP PLEASE!!! check engine light and lowered fuel economy and throttle responce
i dont know goin on my check engine light came on and it got it check out it says bank one is too lean but when i press the gas hard it takes for ever to pick up some times even bogs down almost and when i drive normal that dosent happen it accelerates normal and my fuel economy just sucks now only 11 miles per gallon i was at 17 - 19 any suggestions any one else had this problem and if so help please
I would have to ask you what mods you are running on your car. A lean trouble code could be caused by multiple things... ie. bad 02 sensor, air intake, MAF sensor dirty, throttle body dirty, throttle position sensor bad, or in general you just need a tune.
My car had a SEVERE problem with running lean. it eventually got so bad that I overheated the engine and went into limp mode (engine power reduced mode). I had to get it tuned and all its parts looked at. Don't wait to get that to point. Lean is not good for our engines since they are aluminum, running lean and hotter could hurt them over time.
even if it didn't have the fuel fairy, why in the world would anyone want to spend a couple of bucks and a couple of minutes of time to swap out something like a "fuel filter"?
Pmurder88
my check engine light is on went to auto zone to diagnosic gave me 2 codes, the one is a Supercharger by pass valve stuck, and the the other one say intake flow systen performance. can ya help me plz
Both codes contradict each other..... If ur bypass valve is stuck open meaning bypass solonoid then u need to replace it..... I say ure solonoid will fix both issues just me tho
Last edited by Chevycobaltss3; Jun 25, 2010 at 10:20 PM. Reason: Automerged Doublepost
Turbo Johnny
Feb 21, 2019 09:41 AM
TurboTechRacing
Oct 27, 2015 07:58 AM
