Help! Which plugs??
Help! Which plugs??
which plugs do i run with the 3" pulley system from ZZP? i went to autozone and advance auto parts and they looked at me crazy when i said " i need some ngk brk7e spark plugs"
all they had were OE autolite double platinum .40. and they had platinum. for like 3 dollars. so which one do i buy?
Go to CA and they have 1 stage colder plugs made from irrideum. Get those.
http://cobalt-addiction.com/performance.htm
Originally Posted by poppagun
http://www.southfloridapulleyhq.com/...sss/ec_ngk.htm
thats were i got mine and they had really quick shiping.
Originally Posted by OBSSSD
Copper isn't "low grade" friend - it simply performs better and requires more frequent changes. Iridium and/or platinum will detonate easier with more boost
Well all I can say is, I hope i'm right cuz I just spent $30 on the irridium ones. But if I'm wrong then I'm sorry for posting BS.
The irridium plugs are more expencive because they're supposed to last for like 100,000 miles, while the (cheap) copper core plugs offer better performance but need changing every ~12,000 miles.
And thats why, if your buying the copper ones, you buy like 4 or 5 sets of them. Heck, for the cost 5 sets will cost you less than $30. Then you just change them every second oil change (if you go to 5k or a lil more with full syn like I do).
That's right copper plugs should be changed more frequently but there is no debating they are the best for high performance use. Not to bag anyone but frankly there's no debate on this topic among those in the know
I asked everyone I know and they all say the same thing... Irridium is better. It's a more concentrated tip and a superior conductor. Maybe your not gapping them right?
Originally Posted by BallsoutBalt
Why would you get detionation with Irridium and not with copper?
I just can't see that. All parts of the car are gonna be warmed up after 2-3 minutes of driving. After that, everything is ready to roll. The Irridium plugs will resist heat, wich means that they are gonna stay right where they need to temp-wise. Where as the coppers will just keep going up. They are more of a constant than the copper plugs.
Well I can see this will never be solved. But just one more thing, There is no way a any spark plug is gonna cool down more than another inbetween sparks. Each plug is sparking about 12 times per second at 3000 rmp's. No way anything is cooling with that much heat being put through it. However:... Eh forget it. Theres no winning this. Have a good time with you copper plugs.
