Help removing two throttle things on top of tranny
Old Nov 4, 2006 | 03:22 AM
bdwarr6's Avatar
i dont know what they are just need to know howto remove them
allen wrench on the side part wont work, tried to just pop them off doesnt work, tried to pry them off and no luck any ideas?
Old Nov 4, 2006 | 03:26 AM
06' SS2SS's Avatar
Is that the shifting mechanism on the tranny? If it is, those are probably splined shafts sticking out. Take those allens out and maybe a little heat will get those off.
Old Nov 4, 2006 | 03:30 AM
bdwarr6's Avatar
they arent allens
and yea i think its the shifting thingy on the tranny
they arent allens they look like this
_
its a half circle gig
Old Nov 4, 2006 | 03:44 AM
06' SS2SS's Avatar
Its not a roll pin, is it? If not, sounds like you will need a special tool.
Old Nov 4, 2006 | 03:45 AM
bdwarr6's Avatar
wtf is a roll pin?
Old Nov 4, 2006 | 03:53 AM
06' SS2SS's Avatar
http://www.engineersedge.com/roll_pin.htm
If it goes all the way through, it is more than likely a roll pin
Old Nov 4, 2006 | 04:04 AM
bdwarr6's Avatar
Old Nov 4, 2006 | 04:10 AM
06' SS2SS's Avatar
You will have to get a punch and knock it out. those things are a bitch, so be careful! patience is key. Those things aren't made to come out easy. Use lots of WD-40, or if you can get Kroil, that's the ****.
Old Nov 4, 2006 | 04:17 AM
2K5SS/SC?'s Avatar
Just pop off the plastic pieces. No need to remove the roll pin.
Old Nov 4, 2006 | 08:21 AM
djt81185's Avatar
Just get a big fking screwdriver and pop em off...ive done it a few times thats all u need to do
Old Nov 4, 2006 | 08:51 AM
2K5SS/SC?'s Avatar
Amen to that brother!
Old Nov 4, 2006 | 10:06 AM
SuperCobaltSS's Avatar
I just used a big screwdriver and popped the linkages off takes like two minutes
Old Nov 4, 2006 | 11:06 AM
Boosted_SS's Avatar
was sitting here think the same thing about the screw driver. but then i thought maybe he likes the smell of WD-40. LOL
DarrenGC
Dec 24, 2021 01:55 PM
Oct 13, 2015 09:32 PM
OrangeCoba
Oct 1, 2015 10:00 PM
Iceberg
Sep 29, 2015 12:33 PM
Iceberg
Sep 28, 2015 01:31 PM
