help! SS isnt running
Old Sep 30, 2007 | 10:01 PM
wes_woodbridge_ss's Avatar
I'm in a heap of **** right now, not sure what to do. Had a custom 3" header and exhaust installed about two weeks ago. Was running fine for a few days until i got a CEL (O2 bank 1) still running fine. Then the car decided to go into limp mode and cut the power. Fine rest the computer. The CEL would come back and limp again. Had it hooked up to a diagnostic computer for a test drive and found bank 1 was running lean (negative readings). The car was running fine all tyesterday until at night when it limped again. ita hasnt reset since and now will bairley idle. What r my options? Hp tuners?
Old Sep 30, 2007 | 10:05 PM
07SSCharged248's Avatar
what mods do you have that call for a 3in exhaust....
Old Sep 30, 2007 | 10:15 PM
Gm stage 2. dont require the 3" jus got it incase. i like doin things once. most of the time.
Old Sep 30, 2007 | 10:22 PM
intense_SS's Avatar
where the car tells you the temp, did it say something about a power loss?
Old Sep 30, 2007 | 10:26 PM
yup, engine power reduced
Old Sep 30, 2007 | 10:29 PM
intense_SS's Avatar
did you also recently change the oil or do anything in the engine bay?
Old Sep 30, 2007 | 10:35 PM
did oil, had the oil reset, engine temp is always normal.
Old Sep 30, 2007 | 10:36 PM
intense_SS's Avatar
did you change the oil or a dealership or something like that?
Old Sep 30, 2007 | 10:40 PM
had my mechanic change it. put 4.7 litres. fluids r good.
Old Sep 30, 2007 | 10:44 PM
intense_SS's Avatar
ok well usually when people change the oil on the ss/sc's they have to on hook some stuff to get to the filter and what not, so I guarntee that there is something unhooked in your engine bay somewhere, and you just have to find it, go out and look around and feel every wire and make sure everything is connected, because i am sure that is the problem. This also happened to me when my cars iol was changed the first time. I do it myself now lol, but it shouldn't be anything too big to worry about ma, just check out ur engine bay, and let me kno
Old Sep 30, 2007 | 10:47 PM
but y would it throw the negative o2 and a t.p.s. code (sorry forgot to put that in the beginning) I'm jus real pissed right now.
Old Sep 30, 2007 | 10:49 PM
Blur.fx's Avatar
Pave It All...
TPS = Throttle Position Sensor? Isn't that right near the oil filter? -hinthint-
Old Sep 30, 2007 | 10:50 PM
intense_SS's Avatar
because if something important is unhooked that it can cause other things to mess up, so u need to find the source and fix it there then see if there are any other problems. but start looking in the engine bay wires
LopsidedJester's Avatar
well, did your o2 sensor get messed with during the install? they could have hurt it possibly. do you have any hoses off on your intake or lose connections? that would run air past the MAF and throw a lean code.
Old Sep 30, 2007 | 10:51 PM
intense_SS's Avatar
i didnt wanna give it away lol, but ya there u go man thats probably what is wrong!! lol i like people to take care of their own problems tho lol so i was just hinting you in the right direction
Old Sep 30, 2007 | 11:07 PM
i know what a t.p.s. is. I jus thought that it was the o2 that set it off since that was the first code i got. The o2 is stil getting a reading its jus fluctuating between .08 and negative decimals. I'm thinking because the exhaust is too large. please tell me im wrong\
anyone?
Last edited by wes_woodbridge_ss; Sep 30, 2007 at 11:07 PM. Reason: Automerged Doublepost
Old Oct 1, 2007 | 12:25 AM
did you check for exhaust leak? I don't think the o2 sensor cares about diameter, i was running mine off of a primary pipe on my weapon-r (which is 1 3/4") and changed it to the collector which is 2.5". I found no difference
Old Oct 1, 2007 | 01:04 AM
trialskid's Avatar
4.7 is NOT enough oil mine takes over 6 L to be full
you do not need to unhook anything to get at the oil filter if you have the right tools
Old Oct 1, 2007 | 01:08 AM
Mnatvyc1223's Avatar
our cars take 6 quarts... not 6 litres
Old Oct 1, 2007 | 07:53 AM
trialskid's Avatar
6 quarts = 5.7 liters.
if you put that much in its not enough...at least on my car.
Old Oct 1, 2007 | 09:35 AM
besides oil, any other suggestions for a fix?
Sl0wbaltSS
Nov 21, 2018 11:11 PM
Zharrington_2010LNF
Feb 8, 2016 01:43 PM
tomj77
Oct 4, 2015 11:39 AM
dieGone
Oct 1, 2015 06:27 PM
Extremespeed
Sep 29, 2015 04:34 AM
