HELP, Stage kit installed/case relearn
Ok so i had my ottp stage 2 kit with a pretuned pcm 2.8 pulley, 60# injectors and ngk step 1 colder spark plugs and the guy that installed it un hooked the battery and it didn't throw any codes seemed to run just fine on the road ( and i know he got on it) and i'm going to pick it up tommorow, do i still need a case relearn? Thanks!
By installing the kit the dealer will claim that almost any engine defect is due to the kit...so i would say good luck
But the dealer can get the case relearn done, or somebody with hptuners and some people can get it done using an interceptor gauge which is what i did a while back and it worked fine...
Thanks
agentirons
Oct 16, 2015 02:11 AM
