HELP!!?? Timing CHain TENSionER?!
Old Apr 13, 2011 | 05:09 PM
s10novacobaltss's Avatar
WHich one do i need? i goto autozone's website and they show two and people say their is a newer updated one or whatever that u can use that you don't have to take everything apart like the valve cover off etc...they show two...one's longer with al ittle bit longer nose or whatever and a shorter one,
Old Apr 13, 2011 | 06:50 PM
13 people viewed so far and no heLP!! oh well, i figured out i need the "compressed" one which is the only one available at oreillys, i'm putting it in tommorrow when i get home from work, hopefully it solves the nasty noise and hopefully nothing else is fucked, oh did i mention my truck broke down and i had to put 300 into it for new radiator etc... like 6 days ago and that night when parked outside of auto zone and checking out a bonehead backed out and swung his front end into the cobalt...so i get to fix the tensioner and then get another estimate then hopefully get the fender/wheel fixed repaired and hopefully the balt will be good to goto florida in june 78,000 miles and counting
Old Apr 13, 2011 | 07:25 PM
RonSS's Avatar
If it's a ticking noise, its the tensioner. Pull your plugs out so your engine settles then use a 32MM socket on the back passanger side of the engine to remove the old tensioner being careful it comes out in once peice. Then replace with the new one from www.crateenginedepot.com.
Replace plugs, proceed on with life as if it never happened. Minus noise.
Joel
This was just posted recently.
Old Apr 13, 2011 | 09:00 PM
CanadianCobalt's Avatar
^ What he (I) said haha.
Don't get the compressed spring one, that's the old style and will fail again. You need the revised tensioner as shown in the link.
Joel
06MetallicBalt
Jul 20, 2025 08:47 PM
Oct 20, 2015 09:56 PM
justinchinn
Oct 2, 2015 12:18 PM
SSLOW06
Oct 1, 2015 07:21 PM
dieGone
Oct 1, 2015 06:27 PM
