HELP!!! Trans Grind
HELP!!! Trans Grind
When I shift from 1st to 2nd my trans sometimes makes a electronic grind noise. I maybe thought i wasnt pushing my clutch in all the way but it does it when i have the clutch push to the floor.....is anyone else having this problem??
I'm not sure if the crunching is the transmission on my LS or not, but I find going from 1st to 2nd is incredibly tight and sometimes makes more noise than I'd like to hear when shifting into second gear. It's not quite a grind and it's not quite a crunch it's hard to explain...I'm temporarily blaming it on the car being new but am going to have the dealership look at it soon if it pesists.
Permafried-
Permafried-
I would make an appt. to have it fixed but when i took it to the dealership to have them replace my 2 rims and an emblem i had the service guy ride with me and it didnt make the noise when he was in the car, of course so i looked like a complete retard.
Anyway...is anyone having a problem with their sunroof visor, it only happens after its been sitting in the sun for a while. i guess the sun heats up the adhesive to one of the foam pieces on top of the visor and when i shut the visor the foam sticks to the glass of my sunroof.
i'm having trouble on my third gear consistantly. when i shift above 4k rpm i miss third almost everytime. it doesn't grind at all, it just blocks me from even hitting third. if it continues in a few weeks, that will be my first service call
if nto get it fixed before they start blaming you for stuff!
