HELP!!! Trans Grind
Old Jul 5, 2005 | 04:36 PM
Emydol's Avatar
HELP!!! Trans Grind
When I shift from 1st to 2nd my trans sometimes makes a electronic grind noise. I maybe thought i wasnt pushing my clutch in all the way but it does it when i have the clutch push to the floor.....is anyone else having this problem??
Old Jul 5, 2005 | 04:48 PM
Permafried-'s Avatar
I'm not sure if the crunching is the transmission on my LS or not, but I find going from 1st to 2nd is incredibly tight and sometimes makes more noise than I'd like to hear when shifting into second gear. It's not quite a grind and it's not quite a crunch it's hard to explain...I'm temporarily blaming it on the car being new but am going to have the dealership look at it soon if it pesists.
Permafried-
Old Jul 5, 2005 | 05:10 PM
codyss's Avatar
Sounds like the shifter needs to be adjusted.
Old Jul 5, 2005 | 05:45 PM
cvenom2122's Avatar
Thumbs up
down shifting? wear the clutch a lil bit may go away if nto get it fixed before they start blaming you for stuff!
Old Jul 7, 2005 | 09:07 AM
Emydol's Avatar
I would make an appt. to have it fixed but when i took it to the dealership to have them replace my 2 rims and an emblem i had the service guy ride with me and it didnt make the noise when he was in the car, of course so i looked like a complete retard.
Anyway...is anyone having a problem with their sunroof visor, it only happens after its been sitting in the sun for a while. i guess the sun heats up the adhesive to one of the foam pieces on top of the visor and when i shut the visor the foam sticks to the glass of my sunroof.
Old Jul 7, 2005 | 09:18 AM
codyss's Avatar
If the shifter linkages are even slightly mis-adjusted it may cause that noise once and awhile.
Old Jul 7, 2005 | 06:49 PM
selfinfliction's Avatar
i'm having trouble on my third gear consistantly. when i shift above 4k rpm i miss third almost everytime. it doesn't grind at all, it just blocks me from even hitting third. if it continues in a few weeks, that will be my first service call
Jan 12, 2016 12:01 AM
Sep 27, 2015 08:53 PM
zdohare
Sep 23, 2015 11:31 AM
