help! unresponsive obd port?
Old Apr 25, 2010 | 07:17 PM
corey_osu10's Avatar
i went to a mechanics house to day to get my cel cleard form gutting my cat. when he hooked the scanner to the ss nothing happened? the scanner didnt even recognize that it was hooked to a car. what would cause this and how do i fix it? fuse? any help appreciated!!
Old Apr 25, 2010 | 07:21 PM
DeepBlack SS's Avatar
Should be a fuse under the hood. I'd make sure to check that.
Old Apr 25, 2010 | 07:23 PM
what would have caused it to blow though?
Old Apr 25, 2010 | 07:25 PM
07cobaltguy's Avatar
cig lighter fuse. been there done that.
Old Apr 25, 2010 | 07:26 PM
TCguy's Avatar
GM frequently uses the cigarette lighter fuse as the same fuse for OBDII, make sure you check that
beat me to it lol
Old Apr 25, 2010 | 07:27 PM
PRND3L's Avatar
i think the fuse is under the center stack, the access pannel is on the passenger side.
Old Apr 25, 2010 | 07:34 PM
so changing the cig lighter fuse should fix cig lighter and obd? but nothing has been plugged into my cig lighter for a while and the cig lighter still works cause it gets hot
Old Apr 25, 2010 | 08:14 PM
Viceversa10's Avatar
something similar happened to me, but it wasnt a fuse, it was just a loose wire. i had to plug the scanner in then literally push down on the odb2 port for it to recognize it was plugged in, then had to hold it there while it was being scanned. kinda sucked lol.
Old Apr 25, 2010 | 08:24 PM
Judder's Avatar
same thing happened to me, as previously stated, it was the cig lighter fuse.
Old Apr 25, 2010 | 11:14 PM
my interceptor should b here tommorrow or tuesday so its not gonna work til i fix the fuse either.. urgh.
Old Apr 25, 2010 | 11:16 PM
thebucky84's Avatar
like everyone else sed, cig fuse... had me jumping through hoops a few months ago to figure it out lol
Old Apr 25, 2010 | 11:24 PM
thanks for the help everybody
Old Apr 26, 2010 | 11:16 PM
ok last question, i dont have the owners manual for my car and the panel has nothing but abbreviations for the fuses. does anyone know what number fuse, or what the abbreviation is?
Old Apr 26, 2010 | 11:25 PM
WickedSS2005's Avatar
ltr
cig
or cig ltr
Old Apr 27, 2010 | 09:47 AM
^^ none of those r choices..
Old Apr 27, 2010 | 05:09 PM
Well ****. Did you check under the hood in that fuse box? That's where it's at
Oct 13, 2015 09:32 PM
goaliemo
Sep 28, 2015 01:37 PM
Sep 27, 2015 08:53 PM
DocSvensk
Sep 27, 2015 02:24 PM
