high compression pistons
Old Oct 31, 2009 | 04:04 AM
RBC's Avatar
RBC
With enough money anything is possible.......... period! if you want to run 20:1 it can happen, how deep is your wallet? If you/or buddy can't build your own engine then don't take anyone's advice on this message board.
Old Oct 31, 2009 | 12:35 PM
Originally Posted by bsbllscnd970
it was a rhetorical response, jesus. he was just saying nothing, not EVEN diamond, could withstand certain detonations. not that there are actual pistons that are made of diamond. he was simply adding to the fact that not even something w/ the hardness of a diamond, let alone metal, could hold against a really high CR and detonation.
christ if he had just put it like that we wouldnt be here
Old Oct 31, 2009 | 12:46 PM
slowswap's Avatar
11:1 with boost is reasonable goal which can be done quite easily. It really depends on your power goal on which way to go. Making decent power with the M62 will require higher compression to keep the blower in its effiecieny range. On 93 octane, don't be expecting numbers that will be that great. You will at least need E85 or 110 or high octane rating gas to make the power. High compression + low boost is the way to go if you don't mind the reduction of power for daily driving or have deep pockets for fuel.
Old Oct 31, 2009 | 03:06 PM
Tennpenn83's Avatar
Originally Posted by Snakes709
the .2L difference isnt going to matter..
you sure about that? the CR is worth noting, yes, but don't say displacement doesn't matter
Old Oct 31, 2009 | 03:52 PM
HunterKiller89's Avatar
troof. thats a 10% increase in displacement...which could very well relate to a 10% increase in power (or more, since more displacement = less boost at the same CFM, which means less compression and heat generated)
Old Oct 31, 2009 | 04:03 PM
Tennpenn83's Avatar
well, in the context he was referring to, the 3.5 vs the 3.7 v6's in the nissan 350z/370z
not quite 10% but you're on the right on the money
Old Nov 3, 2009 | 06:13 PM
Cobaltsky05's Avatar
lmao
Old Nov 3, 2009 | 06:35 PM
Snakes709's Avatar
sorry, let me rephrase...its not going to make that much of a difference. iiunno about other cars but between the 3.5L 350z and the 3.7L 370Z there is a 26bhp increase. Not all 26hp is coming from the .2L of a difference, maybe 8-10bhp. And with that much bhp you might see 1.5whp increase
Old Nov 3, 2009 | 07:33 PM
so 8-10 bhp means 1.5whp? so a stock LNF should put down just above 45whp?
lol
8-10bhp is 7-8whp roughly.. All factors are relevant, and in a boosted application, displacement increases serve several functions that i listed above, and count for even more.
Old Nov 3, 2009 | 07:39 PM
lol
I was kinda wondering about that 8-10 bhp makes 1.5 wheel hp thing too lol
Old Nov 3, 2009 | 07:42 PM
  #36
Snakes709's Avatar
meh whatever....numbers arent exact, i suck at math, ill admit that. But the point still stands when it comes to the 350's and 370's displacement. The 26bhp didnt all come from the .2L increase.
Old Nov 3, 2009 | 10:44 PM
  #37
Tennpenn83's Avatar
26 hp comes by way of increased displacement and a small increase in compression. 10.3 for the 3.5L vs 11.0 for the 3.7L
displacement does matter. you're putting roughly a 6% increase
Old Nov 4, 2009 | 05:13 AM
  #38
troof. 6% increase with about 300bhp from the 3.5l makes 18 more hp
Old Nov 4, 2009 | 12:54 PM
  #39
is this stating that the g37s have 11-1 compression ratio?
Old Nov 4, 2009 | 02:07 PM
  #40
Snakes709's Avatar
yes...at least i think, they have the motor as my car and my engine is 11-1
Old Nov 4, 2009 | 03:09 PM
  #41
i think theyre like 10.8 or 10.9
ineedacobaltss
Nov 7, 2015 02:25 PM
no_ss
Oct 18, 2015 11:58 PM
Tupp
Sep 30, 2015 08:18 PM
Slick_Nick
Sep 28, 2015 09:15 PM
