High flow intake manifold***picking off where rebel stopped**
Ok, I have to say that intake manifold is not too bad for a first try. Considering the space available on the LD9 (I had a GM supercharged Z24 myself so I understand).
The LSJ has a bit more room up front so I could see something just a bit better for it. I would not knock air to air because it I see potential with that as well. Only if I had a TIG welder....
Take this intercooler
http://www.frozenboost.com/product_i...aa811d30e72cef
Use this paint drawing I made, and this should all fit in the area below the blower on the LSJ. I would suggest using a 4-1 setup that flows into pipe for the bottom like a turbo manifold. (Oops I forgot to add the bypass tube, but you can get the jist of what I am aiming for here)
E found a Garrett core that will fit
core itself is 178/each, and according to garrets site it can support 700hp. slowswap drew up a few simunlar designs. Just have to pitch it to Vulcan again, but I know fir a fact they want to finish with cavy asap.
Definitely finish up the customers car first. That should obviously be a priority. Then when it comes time for our hotness, something badass like what I drew up real quick is going to be needed.
manifold pictured is for a cavalier, and it will be supported...car is going to be put thru some diffrent scenrios aswell inc. purposely blowing a coupler, leaving one loose and unclamp'd
I still think a good manifold is needed so we can dump these laminovas and go BIG with an air to water setup. Hopefully one is in the works by someone else?
The one referenced in this thread still looks to restrictive and wouldn't suplly very even flow to all 4 cylinders. We need to keep that in mind as well. Runner length and flow.
The intake manifold can indeed flow a good amount of air, it's really about better cooling of the air that most people are concerned about.
