High perf GM cams?
Old Dec 15, 2006 | 09:50 AM
SuperSport4's Avatar
High perf GM cams?
Has any1 tried out the high perf GM cams?? They r more aggresive then the JBP stg 1 cams and they r not that expensive either....Feedback plz
Old Dec 15, 2006 | 10:02 AM
CTCOBALTSSS's Avatar
I haven't but here is a free bump to get an answer to a good question.
Old Dec 15, 2006 | 10:39 AM
Acidangel_5.0's Avatar
i havent seen specs of either cams so how do you know?
can you post specs?
Old Dec 15, 2006 | 10:46 AM
OniMirage's Avatar
i would like to know as well
Old Dec 15, 2006 | 01:55 PM
cobi's Avatar
Where can the GM 2.0 cams be found at?
Old Dec 15, 2006 | 02:00 PM
DaREDss's Avatar
^^^ Yeah i hadnt heard of this before is it like a accesorie like the stage 2
Old Dec 15, 2006 | 02:38 PM
beltdriven's Avatar
yea tell me the link to that
Old Dec 15, 2006 | 03:50 PM
JMAc88's Avatar
Did someone try, but since they were a race cam they wouldn't fit without some serious mods?
Old Dec 15, 2006 | 04:02 PM
g5mike's Avatar
Try JBP for cams
Old Dec 15, 2006 | 06:05 PM
Asphalt Assault's Avatar
Originally Posted by g5mike
Try JBP for cams
The whole point of this thread was to determine which is more aggressive. GMPP vs JBP
Old Dec 15, 2006 | 06:40 PM
well the gm cam can be found here http://www.crateenginedepot.com/stor...afts-C141.aspx .
88958648 Performance camshaft kit for increased power in naturally aspirated and turbocharged engines. Duration @ 0.050-inch is 268 degrees on the intake and 268 degrees on the exhaust. Maximum lift is 0.464-inch for the intake and 0.464-inch on the exhaust. Lobe centerline is 232 degrees
They r more aggresive than the jbp stg 1
Old Dec 15, 2006 | 06:55 PM
DWK5150's Avatar
Those are for the 2.2 ours have the intake and exhaust cam blanks sam length and the exhaust has the cam drive sensor on it also.
Old Dec 15, 2006 | 07:14 PM
xskier874's Avatar
the 2.0 and 2.2 use the same cams according to jbp or compcam not sure
Old Dec 15, 2006 | 10:56 PM
DWK5150's Avatar
The exhaust cams are not the same the LSJ one is longer for the cam sensor. I have called comp about the cams they have listed for our cars they do not make them it is a listing error.
Old Dec 15, 2006 | 11:22 PM
victory_red_SS's Avatar
LSX RWD S/C conversion
CompCams say they are the same BUT they made a mistake. If you phone CompCams and talk to a rep (I have) you will discover that Comp has no 2.0 cams. They can do a special order but they don't have them in production.
As was already mentioned the cams are different lengths 2.2 vs 2.0
Old Dec 16, 2006 | 05:14 AM
marzbarz's Avatar
on that site it also talks about performance pistons..cheap to. are those as goos as the ones that diamond offers??
Old Dec 21, 2006 | 11:15 AM
BlackSS/SC's Avatar
Sl0wbaltSS
Nov 21, 2018 11:11 PM
no_ss
Oct 18, 2015 11:58 PM
HEATON
Oct 16, 2015 07:21 PM
nathan112i
Sep 30, 2015 07:12 PM
Slick_Nick
Sep 28, 2015 09:15 PM
