Higher boost with Injen CAI
Old Aug 10, 2006 | 08:29 PM
OniMirage's Avatar
I doubt 2 psi extra will generate enough heat to be concerned especially if stock or even gm stage2 since the tune is designed to run rich anyway. Adding an exhaust after that should even it out a little bit but a custom tune should be considered if your running smaller than a 2.8 one would think since that would put you near 20 psi no?
Old Aug 10, 2006 | 09:30 PM
NJHK's Avatar
How rich it is and how hot the compressed air is don't really have much to do with each other.
It's richness is dealing with the combustion cycle, the hotness of the compressed air is dealing with the temperature in the combustion chamber.
Old Aug 10, 2006 | 10:30 PM
OniMirage's Avatar
hmmn
Old Aug 10, 2006 | 10:37 PM
L.P.'s Avatar
I thought anything past 12.5 PSI bled off anyways without that mod on there?
Old Aug 12, 2006 | 11:54 PM
OBSSSD's Avatar
Originally Posted by articzap
intake = more psi generated
exhaust = less psi generated
very well said, and also more power in both cases
Jan 12, 2016 12:01 AM
patooyee
Oct 15, 2015 05:11 PM
717ssbalt
Oct 2, 2015 04:01 PM
Sep 27, 2015 08:53 PM
