higher boost with stock pulley?
Old Dec 23, 2007 | 11:48 AM
Eatonbalt's Avatar
is it strange or weird that my stock car with just an airbox mod is hitting boost levels as high as 15psi right before the rev limiter? im sure my boost gauge is not inaccurate. i have a feeling its due to the very cold temps we're getting here lately in NJ but i can def repeat this over and over again esp. in 3rd gear.
Old Dec 23, 2007 | 11:50 AM
Super_SS's Avatar
LMAO i had same issues. Clogged Cat! I was boostin over 20psi before, idn how accurate it is now :-P
Old Dec 23, 2007 | 11:51 AM
EceSSiveMod's Avatar
haha i just posted a thread exactly like this......everyone told me it was the weather : /
Old Dec 23, 2007 | 12:05 PM
SSdan's Avatar
Could be due to the cold weather and excessive load on the blower in 3rd...
In 5th, my boost creeps from 17.5 to nearly 20 at WOT.
Old Dec 23, 2007 | 02:02 PM
rickyw's Avatar
clogged cat?
Old Dec 23, 2007 | 02:03 PM
an0malous's Avatar
my money is on clogged cat.
its quite common. these cars run pig rich.
Old Dec 23, 2007 | 02:35 PM
SSdan's Avatar
Originally Posted by rickyw
clogged cat?
Mine is simply not that. The cat was replaced the week before I went out and did a 0-160mph pull....But i'm not the curious one here.
Old Dec 23, 2007 | 02:37 PM
an0malous's Avatar
you did a 0-160 pull on a week old cat?
genius
Old Dec 23, 2007 | 02:39 PM
SSdan's Avatar
genius
Hehe..Probably around 2 weeks, and it was definately over the 500mile break in..
If not, oh well!
Old Dec 23, 2007 | 02:57 PM
Onyxd04Redline's Avatar
Running in colder ambient temps will produce more boost.
Old Dec 24, 2007 | 01:51 PM
Eatonbalt's Avatar
im starting to thing its the cat too because i can smell it now after heavy pulls. funny thing is theres none of the normal clogged cat symptoms like bad gas mileage, poor performance, etc. i did notice however that my engine vacuum at idle used to be a consistant 18" but not rides more around the 20" mark. i guess ill have to flex my warranty soon.
Old Dec 24, 2007 | 02:12 PM
Area47's Avatar
Rent me! per hour
ceramic core cats melt at 1200+ degree's.
congrats. you puked another one.
Old Dec 24, 2007 | 04:00 PM
SSdan's Avatar
Time to go catless!
Old Dec 24, 2007 | 04:35 PM
LopsidedJester's Avatar
i saw higher boost with the airbox mod and cold weather, but it was only about 1.5 psi more. With stage 2 i was seeing about 16.5 psi
Old Dec 24, 2007 | 06:33 PM
Super_SS's Avatar
im still seeing 20 psi....damnit :-P
Old Dec 26, 2007 | 02:37 PM
timmy_187's Avatar
I'm having similar problems. Mine feels like its falling on it's face at about 13lbs. (just over the stock setting) It sounds different now too. My Balt is all stock and just started acting up last night. I've had it for about 6 mos. so I don't think it would be a clogged cat. It's boosting to 15+ and I don't know why. Anything over 12lbs feels like I'm losing power. Can anyone help?
Old Dec 26, 2007 | 02:47 PM
Cobalt_SSTuner's Avatar
whats the temperature ouside where you live?
i've seen 18.5-19psi with my stg2 on a cold night
Last edited by Cobalt_SSTuner; Dec 26, 2007 at 02:47 PM. Reason: Automerged Doublepost
Old Dec 26, 2007 | 03:06 PM
WSFrazier's Avatar
If you get more boost with the stock pulley, that is a bad thing and you are losing power. What you want is the complete opposite, less boost = more power (without changing pullies).
As stated, check everything on the exhaust side.
Old Dec 26, 2007 | 03:08 PM
an0malous's Avatar
if you are boosting more than a lb or so higher than your "supposed to"
you have a problem somewhere.
in the frozen tundra, I will still only see about a lb more than summer.
20lbs? your askin for a popped motor lol.
Old Dec 26, 2007 | 03:10 PM
WSFrazier's Avatar
If your touching 20lbs with a stock pulley, you got a clog somewhere.
Old Dec 26, 2007 | 05:18 PM
timmy_187's Avatar
I've got an appt. at the dealership in the morning. I've got a friend with an Ion Redline that said he had similar problems. He said it's probably a clogged converter. It's kinda weird. I'm hitting full boost at less than half throttle. I think I'm losing power due to lack of fuel. Like I said it's stock and I don't think the stock injectors can hang with the higher boost. That's why I'm losing power over 13lbs. If anyone has more suggestions I would really appreciate it. Thanks to all who've helped so far.
Old Dec 26, 2007 | 11:38 PM
an0malous's Avatar
if you are running that much boost on stock injectors, you will be lucky if you havent done some damage already.
you are garunteed running lean up top, and thats asking for broken parts.
stay off that throttle at all costs until its fixed.
Old Dec 28, 2007 | 12:51 PM
timmy_187's Avatar
It was a clogged converter. I also had moisture in the intake side. Kinda sucks that the converter fails that soon. Gotta love factory warranties. The only thing it cost me was fuel to and from the service center.
Old Dec 28, 2007 | 12:58 PM
ItalianJoe1's Avatar
Also, for anyone having issues with this, if its not the cat check to make sure your intercooler pump is working. I've seen a few cars with connection problems, where the plug wasn't in all the way from the factory. Look in the little fill neck with the car running, you should see coolant flowing across the bottom. If not, you will get overboosting and loss of power, and it gets worse in higher gears.
Old Dec 28, 2007 | 12:59 PM
06blackg85ss's Avatar
I hit 14.88 psi on the stock pulley with a 7k redline.
trying to find a screen shot of the log...
